Took the girl out yesterday. Lawdy! What a jet.
I have a Crewzinn too, and like it, especially since it has a CG machine built in. But to be honest, I use my Ernst Ultra Stand more. And it's a lot cheaper too.
https://www.amazon.com/Ernst-Manufac.../dp/B011IP3RXM
PatComment
Have you considered making your own stand out of PVC piping. Usually the 1/2" diameter is more than enough for stability. You can custom design it to the shape you want. For the planes you want it to hold, and for minimal cost. Perform some measurements, cut the pieces to the desired size, test fit them before using the PVC glue, and once happy, carefully glue it together. Add some piping insulation for cushion where the plane will sit, or some pool noodles cut to size, and you're good to go. Chances are that you can get the project done before a manufactured stand is ordered and delivered to you. Also, some PVC pipe cutter pliers are worth purchasing in my opinion. That makes the job much easier and quicker.I realized no stand is a pain ,,,
1_time to get a typical stand to work on F-22 -- seen any good ones to work at the shop and at the flying field ?
2_also i think i saw a partial pic on hobbysquawk of a floor standing stand that you did not need a table to set stand on while in shop , but only caught corner of picture so not sure, was i seeing things or is a floor shop stand avail to work on rc planes ?
thanks !!Comment
Good Morning Guys,
Can i see some install photos of your A3-L and RX1000 please?
I'm after some inspiration.
Cheers,
Phil.Comment
Hi guys, i'm after some help and advice from all that have flown the raptor. I set every thing up by the book - throws and CG - wind was around 15mph gusting up to 20mph Maiden was ok at best the throws on the ailerons were a little high for my liking but it was flying relatively nicely. The landing was a little hot but that's typical of nearly any new plane until I get settled in. The following day I went out again for more flights. The wind had picked up to around 20mph gusting to 25mph. Take offs are lovely and smooth but the rest of the flights never felt locked in and I never got comfortable with the plane. I flew twice and was glad to get the jet down without crashing.
I was expecting this to be an absolute diamond from the reviews and praise on here. I thought it would handle the wind better but it just didn't feel nice. For comparison I flew my eFlite 70mm F16 and that was fine in the wind conditions??
My CG is set at 150mm, throws as manual except ailerons which i've almost halved. Battery is a 5300 optipower which weighs in at 845g
I just wonder if this is sensitive to windy conditions because of it profile, almost flat with big tails??
I want to try it again in calm winds but sometimes you just got to fly in windy conditions or you never fly at all!!
I want to try it again in calm winds but sometimes you just got to fly in windy conditions or you never fly at all!!Comment
That's too much wind for a foamie. I fly in 10 to 15 mph max and dont have the problems you haveComment
I think your expecting too much from the design. It is a draggy airframe to begin with. The wide body lifting fuse can be both a blessing as well as hinderance in gusty conditions. The large vertical stabs don't help much either. I don't know if you have a gyro but it will do wonders in the wind that you are flying in. Consider these models an engineering and design masterpiece. I am very uncomfortable flying a full size 150 /72 in those gusty wind conditions.
dwComment
I’ll fly in that much wind and more, but I usually move the battery forward a half inch to an inch. More forward CG will be more stable in the wind. Had my Venom V2 out in some heavy gusts today and it was a riot.Comment
.png)
