  • sailing1
    • 13
    Hey RCjetDude. Just wondering how much battery you had left after your flights. I have the 8S version set up on one 6S Admiral 5000 (50c) and one 2S Admiral 5000 (60c) to get to my 8S. Temps are great here in Oklahoma but 20 mph winds a bit more than I want to tackle for a maiden in a light weight foam jet.
    • Rcfiddy1
      Professional Crash Test Dummy
      • Aug 2015
      • 186
      • Manalapan, NJ
      Waiting on my receiver to arrive but I got my Fms fan and 150a esc mounted. I’m going to go with a full mix taileron setup. Just wondering if I should mix in some ailerons like on the f14 rcgeeks setup.
        I'd recommend programming two flight conditions in your radio, that will allow you to toggle a switch to enable Aileron mixing. That way, you can evaluate the merits of either configuration. However, before you do all that I'd recommend first maidening in the configuration I set in the manual. This will give you a benchmark for how we intended the model's flying surfaces to be configured, from which you can then experiment and draw your own conclusions as to which is more advantageous for your flying style.
        As for throws, I always program three rates, with the manual's rates being either High or Middle. It's nice to have at least one seeing lower than that.
          Near as I can tell based on an internet search, here's where the extra decals go on the bottom. I have no idea where the extra two large decals would go.
          • JazzmanB
            Flying and drumming in the pocket
            • Sep 2018
            • 85
            • Sf
            4th flight. https://youtu.be/QiQ5_gg-OMY
              For the second flight I had 52% left.
                  You're right, Pat. The four dark rectangles go on the central belly, and the two squares (one light gray and one dark gray) go on the forward belly just aft of the intakes.
                  • WAY BAD
                    • 69
                    • Bossier City, LA USA
                    Originally posted by JazzmanB
                    Smooth flying. 6s or 8s? Everything set up by the book?
                    That's nice to hear. 3 min flight times or 3:30?
                      My timer was set to 3 minutes so I think it could attain 3-1/2 to 4 minutes with throttle management. I doesn't need a heavy throttle stick to fly well.
                      • WAY BAD
                        • 69
                        Rite on. Yeah, you can tell from the videos so far, it looks very efficient in the air.
                        • Felixs10
                          Felix S.
                          • 113
                          • Bergen county, NJ
                          So is everyone liking the C/G call out in the Manual ?
                          • JazzmanB
                            • Sep 2018
                            • 85
                            • Sf
                            [QUOTE=WAY BAD;n166130]
                            Thx, 6s fms 1900kv. Very light setup. The only thing by the book or close was cg and their 5mm of up elevator for neutral is perfect. I dont even look at recommended throws. I just fly: and setup how i like) Lots of elevator btw!!:)
                            • Rcfiddy1
                              • Aug 2015
                              • 186
                              • Manalapan, NJ
                              [QUOTE=JazzmanB;n166168]
                              https://youtu.be/F6knuyy72IE
                              I’m going with same setup. Glad to see it work well.
                              • RuthR720
                                • 71
ID:	166228Click image for larger version
ID:	166229Click image for larger version
ID:	166227Click image for larger version
ID:	166226Click image for larger version
ID:	166225 The quality of this F-22 is outstanding! I’ve noticed Freewing didn’t use lightening holes on the battery tray. Since I have the 8S version I’d like to save as much weight as possible. I’ll probably cut the battery tray the same as in the F-4 Phantom. I saved about a half ounce in my A-4 Skyhawk.
                                  Originally posted by JamesonC
                                  You got a link to what you used?
                                  You'll love this stuff.
                                  • JamesonC
                                    MRC fanboy
                                    • 619
                                    • Laurens, SC
                                    Thanks George!
                                      I made some notations about where to actually place the decals on the bottom per Alpha's reply.
                                      • Pogo
                                        • 452
                                        • Waterford, Ontario, Canada
                                        Thanks Pat- that's helpful! I wonder what they mean?
                                        Hey, look what arrived yesterday! (Not the dogs, they were already here.) A quick examination showed no damage and a beautiful model and away it went till the 25th- c'mon Christmas!
                                        Tom
                                        • Flanker271
                                          Spool up that fan!
                                          • 81
                                          • Gilbert, AZ
                                          For those who couldn't wait till Christmas day and have already assembled the Raptor, could you help me confirm/clarify one step in the assembly process:
                                          When attaching the horizontal stab to the fuselage the manual calls for two 3x10mm screws to secure the pivot rod to the fuselage. The only screws I can find in the parts bag this size are these pan head self tapping screws. Once fully screwed in, the outer screw does not sit flush with the fuselage. It is protruding out by about 1/4" from the hole. Does this look correct? Wanted to make sure I'm not using the wrong screws.
