  • yf22raptor
    Love to fly
    • 75
    No issues on heat ...using heat protection
    8 flights so far ...
    Can take direct heat of up to 500゚ and ambient heat up to 2000 good stuff..
    • VNAF1972
      • Jun 2015
      • 4
      If I were you I will try to add the weight to the front.
      • yf22raptor
        Love to fly
        • 75
        Added led afterburner was a tricky with a turbine in thier but worked it out .And wing tanks ..
        • downwindleg
          • 1279
          • Friday Harbor, Washington
          Click image for larger version Name:	P_20190408_172149.jpg Views:	0 Size:	105.8 KB ID:	189101 O.K. different subject. Just got around to balancing the Raptor and found that the battery(Admiral 5000) had to be pushed so far back to balance that it's out of strap range.:Thinking: Has anybody else had this issue? It's easy enough to cut new slots and move the strap aft but I'm just wondering if I missed something. Forgive all the loose wires as I haven't got everything like the operable canopy wiring and lit instrument panel sorted out yet. Those wires have to be extra long so I can pull the hatch back a ways for battery changing.
          Looks like I answered my own question. I went back to Alpha's preferred setup and found that my battery position is pretty much on. I didn't realize that there are already 3 strap positions(slots) provided and Alpha had moved his back to the middle strap position which allowed the strap to be more towards the middle of the battery while mine came stock with the strap in the front position.:Whew::Cool:
          • Grover54
            Going Weightless
            • Jan 2019
            • 319
            • Seattle Area (Redmond)
            WARNING! – WARNING! – WARNING!
            This may be old news but if your research for products and supplies turns up a RC supplier called VampowerPro or Urban Products Inc. DO NOT I repeat DO NOT try to buy anything from them, not even a screw because that’s what you’ll get!!! I learned the hard way and though I didn’t lose any money (my CC company reversed charges) I wasted so much time chasing them for information. They don’t take calls; their mailbox is full and don’t return any emails and I just learned this has been going on for 8+ years. My bad for not conducting any due diligence on them. I’ve never seen any company as bad as these dirt bags and I’m surprised PayPal hasn’t shut them down so heed the warning!
            • downwindleg
              • 1279
              Hey Grover, good to know for sure. BTW I am back to the original question on battery placement and cg. After I cleared all the loose wiring out of the way and pulled the battery out, I realized that the stock position of the strap is already in the middle position so that means my battery is much further back than Alpha's as a for instance. His is posted at #2141. Has anybody else wound up with their battery position this far aft? I've checked it on my new balancer like three times now using the 150mm back from wing root as shown on the instructions. What am I missing?
                You have cockpit and canopy mods that he doesn't making yours inherently more nose heavy than his right out of the gate. You will have to move your Batt back further as a result won't you?
                • VNAF1972
                  • Jun 2015
                  • 4
                  I mean to the back
                  • downwindleg
                    • 1279
                    That's true Steve and thanks for the input, I also added the afterburner mod to the motor and the streamlining parts which would add a certain amount of tail weight. In any case, I'm wondering what you're battery position wound up being or did you go the 8s version? If anybody else went 6s, I'd be interested in knowing their sweet spot for battery position especially if you did the canopy mod and cockpit upgrades as Steve mentioned.:Confused:
                      • 8218
                      Agree with Steve, Brad...Love the clean look...Well done. And Manfred I still can't get over how exotic and sexy that paint scheme is!
                      • adb2@suddenlink.net
                        Advanced Pilot
                        • Nov 2018
                        • 104
                        • Abilene Texas
                        Not missing anything. Both of mine are at 150mm, marked there and fly beautifully.
                        • downwindleg
                          • 1279
                          Thanks adb2, how far aft did your battery wind up being at the 150mm balance point?
                          • Grover54
                            Going Weightless
                            • Jan 2019
                            • 319
                            This is SOOO Cool! I'm not at the jet level yet - need to continue improving my skill sets but I'm definitely getting there. I assume the LED is tied into your throttle so when you reach X% it lights up? More details please.:Cool:
                            • downwindleg
                              • 1279
                              Yeah, as to the led afterburner, it has a separate controller and battery(small) and you can set it to come on at whatever throttle setting you want like you said. It also actually flickers on and flickers off like the real deal.:Cool:
                              • thisguy65
                                • 509
                                Guess what I just ordered...
                                Planes
                                  Good choice:Cool:. Welcome to the Raptor Squadron.
                                  • Pogo
                                    • 452
                                    • Waterford, Ontario, Canada
                                    Brad, mine is the 6s version as well. Here's where the battery (Roaring Top 5000 @ 740 grams) needs to be for a CG of 150mm. The addition of a couple of ounces with the canopy and cockpit mods so far forward of the CG makes this necessary on our birds. I have the little 280 mAh battery for the centerburner velcroed in place as gar back as it'll go, and the exhaust ducts are lined with foil tape, which helps the nose heaviness a bit. Good thing, as I almost couldn't balance it without adding weight in the tail as the flight battery is as about far back as it'll go.
                                    Tom
                                    • MANFRED
                                      Any Warbird, any time
                                      • 299
                                      • San Diego, Ca
                                      Thanks guys, I realize we haven't sold any raptors to our NATO allies yet, but I couldn't resist. This scheme was actually used at last years Tiger Meet by the Luftwaffe team on a Eurofighter. There is a great video of them applying this scheme. It is actually done with a vinyl wrap and is amazing! Hope to maiden this weekend.
                                      • downwindleg
                                        • 1279
                                        Tom
                                        Hey Tom , that is exactly the response I was looking for and within an 1/8" of where my battery wound up. Thanks for stepping up and helping my friend.:Cool:Just needed to know I wasn't off my rocker.
                                          Advanced Pilot
                                          • Nov 2018
                                          • 104
                                          • Abilene Texas
                                          You know I didn't measure where the battery was, I just moved it to the point where it balanced at 150mm and marked it. To me that was all that was needed. The batteries being 5000 mah to 5500 mah.
