  • gooniac33
    The Original Gooniac
    • Jun 2016
    • 1047
    Just a lil Combat between the F-22 and Su-30... its hat cam so not the best but still fun!!
      • 4838
      gooniac33 , Great vid and big fun. Best, LB
      • Gary9648
        • 16
        I now have installed the thrust vectoring nozzles. Pins are holding them in place until glue cures. I used non-foaming clear Gorilla glue. I do not want these to come loose. I am now waiting on servos and control linkages to complete. I used Tamiya titanium paint for edges and a dark metallic silver for the middle of the nozzle.
        • GarrisonR
          • Jul 2019
          • 56
          • La Mesa, CA
          Pretty clean, would love to see them operating when you get it it running!
            • 5398
            Me too. Are the gears out of the airstream?
            • Gary9648
              • 16
              Yes the gears are not in the airstream. They are off to the side and the nozzles have air streaming around the gears to allow smooth airflow at the side.
              • Gary9648
                • 16
                Here are a couple of photos of where I’m at installing the vectored nozzle set. After cutting out the fuse openings for the servos, ( I will glue them in place with Gorilla glue) I proceeded to lengthen the servo leads and wanting to have no connectors to allow me to pass through foam and then forward to receiver area. Notice not he’s in fan lid to allow servo leads to pass. I then taped the servo leads to the side of the front intake with packing tape to minimize any airflow restrictions or cause turbulence. I then wire tied them to the wing spar before passing them on into the battery area.
                • Raptor Rich
                  • Sep 2019
                  • 2
                  I have been flying on a Futaba 8U for years and I was hesitant to maiden my F22 on an older radio so I finally bit the bullet and I bought a Futaba T10J radio. Problem is I'm going nuts trying to figure out how to set the Elevator Flap mix. I can't get the elevator to respond when I deploy the flaps.
                  Buying a new radio is like going back to first grade!!!
                  Can anyone help with this?
                  • Gary9648
                    • 16
                    Well it’s going to be a while for finishing up my F-22 vectored thrust. When I ordered the plane and all the radio equipment I needed only a 6 channel Rx so I opted for one with stabilization and thought that would be great. I had no idea thrust vectoring would be available at the time. I had forgotten I had installed a 6 instead of 8 channel Rx. Soooooo now I have to wait until the 8 channel Rx with stabilization arrives. I will definitely need 7-8 channels for this set up. Bummer! Oh well I can at least finishing up the Y harness before it gets here. Also I can maiden the plane without the vectored thrust electronically connected. I’ll just center the servos and connect up the pushrods in neutral position and fly!
                      • 5398
                      Be careful, it is possible the servo could be moved by air pressure on the petals. I suggest pinning them some way.
                      • Gary9648
                        • 16
                        Thanks for the advice, I will do that
                        • Raptor Rich
                          • Sep 2019
                          • 2
                          Never mind I figured it out.
                          • Gary9648
                            • 16
                            Here is my soldering station on top of the fuse while attaching connectors after pulling wire through fuse. Second photo is the finish set up. I used good old Z bends to attach push rod to servos and ball links at nozzles
                              • 5398
                              Looks great, you’re going to have a good time with the TVs​​​​​​.
                              • Bajora
                                AA6JB
                                • 462
                                • Sonoma County, California
                                Clubmate Michael Troy's Freewing F-22, as shot a few days ago.
                                • mshagg
                                  • 541
                                  • South Australia
                                  Finally joining the club! This is one of those builds that goes together so quick you're left wondering "what did I forget?"
                                  Assembled with an afterburner and a tuned S6R before dinner. 3D printed a nose wheel brace and will probably detail the cockpit with the 3DPUP bits and pieces.
                                  I'm not much of a modern jet guy, but this thing is pretty easy on the eye.
                                  Here she is getting to know her new roomies (one of whom is going to have to give up their spot on the rack). Triple check of the preflights tomorrow and should get out for a maiden this weekend.
                                  • gooniac33
                                    • Jun 2016
                                    • 1047
                                    Nice to see that he is liking the burners!! I can't wait for this stuff to be over so I can go visit you guys out there...
                                    • mshagg
                                      • 541
                                      • South Australia
                                      Chased out the panel lines with a dark lead pencil and got a few coats of clear on her today. The panel lines arent really intended to weather the plane, it's more akin to a pinwash (learned that from painting the heng long tanks!) to make the detail pop a little and make the jet seem larger than it really is.
                                      Centreburner is a 'cyclone' from RC Castle. Much love to the community members who make the afterburner kits (I have them on my jets too!) but stateside shipping and the current aussie dollar rates against the USD are killer. The cyclones are great units for the price - nice and bright, neat flicker effect and a button on the controller to calibrate the throttle axis.
                                      I would have maidened her tomorrow AM but the battery in the ute (like a truck but built around a sedan - see pic) is dead flat. So, fingers crossed for sunday. In the meantime, cleared a nasty clog in the 3D printer hotend to pimp out the cockpit.
                                      • mshagg
                                        • 541
                                        • South Australia
                                        Can anyone advise where the STL files are for the bits behind the seat? They dont appear in the .zip file on the website.
ID:	249723Click image for larger version
                                        • Gary9648
                                          • 16
                                          Beautiful photographs my friend. I can’t wait to maiden mine. Weather really is bad here in SW Ohio along with stay at home order.
