  • Mizer67
    • 374
    Originally posted by mshagg
    Is that the powerplant from the high performance F15?
    Yes, it is. I only have a dozen or so flights on it but it's a noticeable improvement for the F-22.
    The vertical vs. the stock motor I measured a ~220 ft. improvement in maximum height achieved, given the ~10% increase in installed thrust. Top speed is basically identical to the 9 bld 1750kv EDF. I notice about a ~10% increase in efficiency with the inrunner, in spite of the higher blade count.
    It does make the plane 115 grams or so heavier.
    • KSEA
      • Aug 2020
      Hello everyone, MRC suggested I ask this question in the forums. Does anyone know what material or product is used to tint the cockpit canopy? If not, I'm open to suggestions from those who have added this to clear canopies. TIA.
      • Pete
        • 85
        Quick question.
        What is the flight time difference between regular old version F-22 90mm and new one performance version.
        Is it shorter or longer if we perform same flight?
        If new system performance one is more efficient I would assume flight time is longer. Is it?
        • Oachidori
          • 52
          • Bucharest, Romania
          Waiting for the maiden: https://youtu.be/yoLAHM_zCG0
          Badan Kit - Yak55M 2.8m; EF - Extra 300 2.3m; Multiplex - Funcub;Funjet Ultra2;Parkmaster;FW - F22 90-X45 Xicoy;ROBBE MISTRAL 2.0
            • 5402
            The elevator to flap mix you have, down elevator to up flaps, may be counter productive. On normal airplanes flaps cause up pitch or spoilers down pitch. On the F-22 and some jets it's opposite. In your case the up flaps or spoilers may contradict each other. Assuming you added the up flaps to have more pitching effect.
            • Oachidori
              • 52
              it seems i made like you:
                • 5402
                Yes, I did it and don't use it because the "feel" is bad... Don't forget I also have TVs that add to my pitching moment.
                • Oachidori
                  • 52
                  So you suggest me do not use this mix? elevator and flaps. I have to use only elevator ? I don t have TV as you see.
                    • 5402
                    Not use or reverse the mix.
                    You can try it both ways to validate my results.
                    • Alpha10
                      J e t - J u n k i e
                      • 377
                      • Chicago
                      This is correct... The F22 likes a little UP EL with flaps deployed.
                        • 5402
                        From a different perspective. Yes a little up compensation because the F-22 slightly pitches down with flaps to keep level. He is mixing flaps to pitch. To get more pitching down flaps with down elevator and up flaps (spoilers) with up elevator would give a slight (very slight) increase in pitching.
                        • Mizer67
                          • 374
                          I've found this is CG dependent. With a neutral or slightly tail-heavy CG, the F-22 will pitch up with landing flaps and not want to drop the nose without down elevator input. It's actually kind of cool that it'll lock into alpha this way, but for me I'd prefer level flight so I don't get too slow.
                          With a more nose-heavy CG it will pitch down slightly, unless you're going too fast for flaps in the first place.
                          I've got another 115 grams towards the rear now with the heavier 1835kv 12-bld motor I have and this is what I've seen. My plane as I have it right now will fly inverted with no down pressure on the stick, so it's a very rearward CG. I made more room up front to move my lightest batteries forward to make it a little more nose heavy to eliminate this tendency.
                          YMMV - I did not notice this with the stock motor.
                          • Teegat
                            Warbird addict
                            • Nov 2015
                            • 13
                            • Indianapolis, IN
                            Did the 6S PNP outrunner version of the F-22 disappear from Motion's web site? Looks like maybe F-18 Blue Angels too. Strictly inrunner versions from here on out? Twisting my arm to get the high performance versions, I think I can handle that!
                            • Oachidori
                              • 52
                              I saw on fb a movie with a F18 take off from a carrier. I saw that it has full flaps down, elev up and the two rudders like a brake, as Evan made its setup. What for is use the rudders like a brake for take off?
                              • Waconut
                                • Feb 2020
                                • 310
                                • Cincinnati, Ohio
                                The rudders turned will help push the tail down for a high alpha attitude on launch. On the full scale this is all programmed in to the flight control system and it takes care of the first few seconds of flight upon launch from the catapult. The pilots hands are not even on the control stick during launch.
                                  • 5402
                                  Because instinct would be to push the stick forward immediately as it pitches up as soon as the shuttle moves.
                                    • 8238
                                    Yes we have been actively upgrading our jets to inrunners with the new 9-Blade system. Sometimes the old outrunner PNP versions can still be found in our sale section if they are not out of stock. Otherwise they will no longer be visible on the website(s). Outrunners in these jets is so 2019!
                                    • Skosh25
                                      • Mar 2019
                                      • 177
                                      • Denver
                                      Flew my 8S today and I powered the receiver with a dedicated receiver battery this time instead of the UBEC. It flew fine but for some reason the landing light wouldn’t turn on. As soon as I went back to the UBEC it worked again. Can’t figure out why. Is it a voltage issue? Stock power system. Receiver battery is a Spektrum 2S LiFe 3000mah.
                                      • Wrthog
                                        • Feb 2020
                                        • 55
                                        Too high of voltage I’m suspecting, do you have telemetry to see what difference in voltage is between the ibex and dedicated life pack? I’m assuming 5.9 to 7.2 fully charged life dropping to mid 6s during use.
                                        • Skosh25
                                          • Mar 2019
                                          • 177
                                          • Denver
                                          Futaba receiver. No telemetry setup but checker showed nominal 6.6V on the LiFe after 3 flights. The jumper on the UBEC is set for 5V.
