    Wow how cool is that!! No pressure or anything! :astonished:
    • Airguardian
      Post Stall Svengali
      • Aug 2020
      • 1687
      • Catalonia
      Originally posted by uscanuck1xa
      I was surprised when the pilot of that actual demo jet got in touch with me to let me know he thought it looked amazing after he saw some photos I posted and he wants to see the video when it gets in the air!
      Now that's amazing!
      BTW, why does that Hornet feature a side light?
      Have not seen it before... maybe to make ground crew life easier?
        • 4873
        Now that's amazing! BTW, why does that Hornet feature a side light?Have not seen it before... maybe to make ground crew life easier?
        AG, Some Canadian, Kuwait, Finland, and Switzerland Hornets were fitted with a high-power spotlight for night operations. The light is located inside the panel used to load the cannon gun (Door 6) as seen on uscanuck1xa's modification. And a great mod it is!. The light was originally used to aid in intercepting and identifying Russian aircraft during the "Cold War". Most CF-188s have the provision for the mod, but not all airframes were fitted with it. A 'blank off' panel/plate was fitted in that case. Best, LB
        • Airguardian
          Post Stall Svengali
          • Aug 2020
          • 1687
          • Catalonia
          Oh, gotcha!
          Now, that's interesting, haven't ever come to think about it... so basically shining a light to the plane on your left to see it (squadron markings and all) during night ops... clever!
          Thanks!
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1687
            • Catalonia
            So, here's a look at my hands while flying the Hornet, giving some insight into how I approach maneuvers like the tailslide or cobra maneuver.
            Have fun!
            PS: The second half of the video is in slow motion and is easier to 'analyze'. ;)
            • Cape Jets
              Member- Jet Jockey
              • Dec 2020
              • 120
              • Cape Cod, MA
              I have the "old" 3748-1750 Kv outrunner in my F-18 and it still flies well and takes off of our grass runway in a short distance, so the fan from your F-15 may work OK. On the other hand, if spending a few more bucks on the F-18 is no big deal, I would still REALLY recommend the upgraded 9 blade 1900 Kv inrunner they now come with, or even much better, that same 12 blade 4068-1835 KV inrunner you put in the F-15, definitely my favorite 90mm Motion EDF. I would put that in every 90 mm I have if "money was not an issue". I have it in my F-16 and love it, it has the quintessential whoosh sound (no whining here) and has great initial thrust to get off grass. Elbee just put it in his new F-18 and we're awaiting his opinion on it.
              Went with your option of the 90mm 12Blade 4068-1835 In-runner from my F-15 for the new Blue. Also went with the Admiral RX700T with a Hobby Eagle A3 Super gyro. So the F-15 will get a FMS 8S EDF with a 150amp ESC 8S. Still have a 90mm 12 Blade Out-runner with a 130amp ESC laying around. F-16 Thunderbird seems to be next for the hanger....Thanks for the idea.....
              • Cape Jets
                Member- Jet Jockey
                • Dec 2020
                • 120
                • Cape Cod, MA
                • Cape Jets
                  Member- Jet Jockey
                  • Dec 2020
                  • 120
                  • Cape Cod, MA
Name:	Gloss 12-25-20.JPG
ID:	291520Click image for larger version
Name:	Gloss Rear 12-25-20.JPG
ID:	291521Click image for larger version
Name:	Gloss Wings 12-25-20.JPG
                  Well seems I was a good boy this year after all. Who knew! Well the new Freewing F-18 Blue Angel has officially joined the fleet. Just had to put a fresh coat of poly on her to make the blue pop.....Man did it ever.... what a difference... Will give it plenty of time to dry, soft sanding and another coat for finish her off. Then on to the fun stuff, 90mm EDF In-Runner 12Blade 130amp ESC, receiver, gyro, afterburner and New HiTec servo's for the elevator with upgrades, install, Battery tray floor and some more minor painting.........
                  Great winter project.....
                    • 2716
                    WOW, what a difference with the poly, looks almost like a monokote surface. Put that baby at the head of the fleet.
                    • Mizer67
                      • 374
                      Looks 10X better with the gloss coat, I agree.
                        Yep, that gloss looks BOSS. Really dig that effect. So hitting it with poly gloss, multiple coats?
                        • Cape Jets
                          Member- Jet Jockey
                          • Dec 2020
                          • 120
                          • Cape Cod, MA
                          Thanks guys....😉That was just a first coat. Used Minwax Polycrylic / water based with a foam brush. I plan on letting it dry really good then a soft sanding to get some minor imperfections out. Then another coat of the Minwax to finish. I was amazed on how the blue popped when the poly was applied.
                          • Polyphren
                            • Dec 2020
                            • 37
                            Hi, the gloss looks very fine. You no longer expect a foam plane :)
                            Here is mine. Today I started the first weathering effects.
                              • 4873
                              PP, Great livery choice & amazing work on the digital camo repaint. Bravo Zulu, Sir. Best, LB
                              • SanExup
                                • 912
                                • Western Wy.
                                Wow! Polyphren how did you do the digital camo? It looks really clean!
                                • Polyphren
                                  • Dec 2020
                                  • 37
                                  That´s all you need...
                                  ...and patience!
                                  All in all it took me 6 days
                                  • SanExup
                                    • 912
                                    • Western Wy.
                                    Ha, ha. Did you paint up against the straight edge or make small templates? Your jet looks really good, the proportion and layout look spot on.
                                    • Polyphren
                                      • Dec 2020
                                      • 37
                                      First, I thought about using templates, but at the end it‘s no advantage. In contrary, you loose the feeling for the proportions. So I took a soft lead pencil with a relatively butt top to avoid hurting the planes surface.
                                      For filling the sketched shapes, I used the brush above and a second smaller one. Normally, you should at least apply to layers of paint, to get a ****geneous painting.
                                      • Polyphren
                                        • Dec 2020
                                        • 37
                                        Weird, the auto correction corrected me. I try another formulation „...uniform painting/ surface“
                                        • SanExup
                                          • 912
                                          • Western Wy.
                                          So essentially freehanding to the lines? Steady hands!
