  • Dkurtzid
    • 22
    Alpha,
    if you’re listening, it seems like a Gulfstream V would be a natural progression after the successful AL 37.
    A lot of groundbreaking design issues have already been resolved with the freewing A-10 and the AL 37.
    Don
    Click image for larger version  Name:	6AFA4B30-55C3-44E9-8698-C1F8815A6FBD.jpeg Views:	0 Size:	8.7 KB ID:	234554Click image for larger version  Name:	E015907C-942B-4F16-BCC3-29FD34F5282F.jpeg Views:	0 Size:	35.4 KB ID:	234556
    Click image for larger version  Name:	5B864B2F-E0DE-46C6-BE77-E7298171C9E1.jpeg Views:	0 Size:	94.8 KB ID:	234553Click image for larger version  Name:	FC4199C0-6BD3-44E5-9BB8-7BAA9C635C99.jpeg Views:	0 Size:	47.7 KB ID:	234555
    • borntoolate
      Bomber Bob
      • Mar 2013
      • 424
      • California
      It has been a long time coming, but here is my AL-37. She is in Southwest Airlines N955WN "Arizona One". This was probably my toughest paint scheme to date. Decals by Callie Graphics, of course! Maiden soon...
      Bob
      • slamdance64
        • 70
        • Ottawa, Ontario, Canada
        Originally posted by OsideRCflyer
        AL-37 to P-8 Poseidon conversion. 3D printed dozens of fins and blisters, radome, targeting ball, pylons, engine nozzles, weapons and new wingtips.
        That is an amazing job. I am going to do the P-8 but Canadian markings. I have just ordered the AL37 but I do have a 3D printer. I am interested in the files if you are will to offer them up for a price. I hope Callie has installed another Vinyl cutter or three to help out with deliveries :-)
        Go Navy!
        Brent
        • MANFRED
          Any Warbird, any time
          • 299
          • San Diego, Ca
          Can someone tell what the 2 extra lighting wires connected to the blue box with long leads and pushed into the wing root are for?
            • 8749
            I haven't put my wings on yet but I believe those are to connect the corresponding wires in the wing that goes to the lights. Take a look at the fat ends of the wings and you'll see one set of 2 conductor wires in each.
            • mshagg
              • 541
              • South Australia
              I haven't run a multimeter over them, but guessed they were for the sequenced lights near the root of the wing, hence why the connect to the blue box and not the main wing connector.
              • urrl
                • Oct 2013
                • 494
                I don't use them and all lights seem to be working. I think I may have tested them and they seemed to be blinking so I left them alone. Might come in handy if I want to change out the solid tail lights.
                • Scale Freak
                  • 54
                  • Leduc, AB. Canada
                  Just a comment on the use of aluminium tape on the leading edges, I tried it on other aircraft as it looks very cool, BUT, any dings or dents it gets are permanent and after a bit it will look like crap. I found some silver self stick vinyl and it works like a charm.
                  It also is forgiving of getting banged and bruised and will conform to shapes better than the tape.
                  • 4923crew
                    SoltProductions
                    • 160
                    • Syracuse, Utah
                    Pictures of the First Flight of my AL37 made into a Kc-135.
                    Video below:
                    Flight went perfect, the new Double Bogie Struts did exceedingly well for custom made.
                    Thanks for all who helped this project
                    J.M. Burulcich- Motion Rc and Freewing (Airframe)
                    Tom Mansell - Landing gear mod- 3d design work
                    Shawn Sagen- pictures taken
                    Callie Soden- Decals
                    Andrew O'L
                      4923crew That is just sooooo fantastic Bro!!! Bravo!!! Great, great job... Can it hover??? Love it!! Jerry
                        • 8205
                        Incredibly impressive! Really fine work there 4923crew !
                        • Wild Man
                          • 526
                          • Rapid City, S.D.
                          I agree you are making all of us Incredibly impressed I have had 5 guys call me and ask me if I had seen your C-135. I use to work out by Ellsworth AFB here in SD. Also watched them refuel the B-52 years ago north of Alzada Montana, years ago while i was still working for Cat. still working on mine
                            • 8749
                            OK, the wing tips have 2 lights in each housing. The inner ones are solid (one side is green, the other is red). The outer ones are white and they blink. It is this light on each side that the dangling connector is for. If you don't plug them in, you will think that ALL the lights work. Plug it in on each side and you will see. That ones on the wing root are white and they only come on when the gear goes down.
                            • 4923crew
                              SoltProductions
                              • 160
                              • Syracuse, Utah
                              The wing has Landing lights, Anti-k lights and Marking lights (Red-Green). The one you speak of is the one in between the engine and the fuselage.
                                • 4820
                                4C, Picture #234807, the shot from slightly below and aft with extended boom is my fave. Great execution of a true USAF workhorse. Outstanding. Best, LB
                                • LowandSlow
                                  • 40
                                  • Lake Tapps Washington
                                  Finally got her out for some pictures and taxi. I'm pulling the gyro out then checking CG and getting it in the air!
                                    • 8749
                                    Not on mine (meaning the landing lights are not controlled by those loose connectors). The one between the engine and the fuse is white and comes on when the gear goes down. Yes, those are the landing lights BUT, the loose, solitary 2-conductor, mated plugs, work the outboard blinking tip lights (I believe those are the wires that MANFRED asked about). It's like on the real 737 when it comes in for a landing. You see them particularly at night, head-on. They are like the headlights on a car. The ones I (and MANFRED) speak of are the loose connectors - the one on the wing root is the one that's shipped with the end pushed into the spar hole; the one on the fuse is the one that's pushed into the a foam slot near where all the other loose ends are pushed in. The two ends are mated - one is male, the other female. When the plane is powered up, with the multi-plug plugged in and then you plug those loose, 2-conductor, mated plugs together, you will see the outer wing tip lights come one and they blink. All the lights on the wing are controlled through the multi-plug EXCEPT the very end lights on the wing tips.
                                    Just so we're all talking about the same thing:
                                    Click image for larger version  Name:	IMG_3526.JPG Views:	0 Size:	61.0 KB ID:	234883Click image for larger version  Name:	IMG_3528.JPG Views:	0 Size:	50.1 KB ID:	234884Click image for larger version  Name:	IMG_3527.JPG Views:	0 Size:	55.5 KB ID:	234885
                                      You guys are making my year with all these refinishes, conversions, and customizations!
                                      LowandSlow I like your sharp masking work on the underside fuselage's silver. It contours well around the mid-section, which isn't easy to do.
                                      Dkurtzid We have similar tastes!
                                      borntoolate Seemingly seamless transitions between paint and decals on your full coverage bird, Bob. Exceptional, as always!
                                      • avanti127
                                        • Apr 2018
                                        • 96
                                        I purchased Model Sounds Inc. Sound system for the my Max. Hope to have it installed tomorrow. I will take pics of where I mounted everything and how it performs.
                                        • avanti127
                                          • Apr 2018
                                          • 96
                                          Video below:
                                          The extra weight of the 2 additional engines and the main retracts obviously had no effect on the flight characteristics so I am going to start flying mine with twin 5200 batteries.
                                          Andrew O'L
