  • ridgerunner
    • Nov 2017
    • 275
    • Central Utah, USA
    Well that certainly answers the question I had. Just curious - what was the combined weight of the two batteries?
    • urrl
      • Oct 2013
      • 508
      1450g for two 5000mAh batteries
      • avanti127
        • Apr 2018
        • 96
        My HobbyStar 5200 are just over 1200 grams paired.
        • urrl
          • Oct 2013
          • 508
          Do you have a link? They are heavier than mine on Amazon. What is your C rating?
          • avanti127
            • Apr 2018
            • 96
            https://www.amazon.com/HobbyStar-520...614291&sr=8-17
            They are 45C. They are both around 610 grams each.
            • LucB
              • Jan 2019
              • 23
              I worked on mine. Foam filler at the fuse junction, sanded wet with 2000, then repainted white with acrylic (paint for kitchen and bathroom from DIY store, 2 light layers with sanding in between). Silver is from foam paint can, grey is from Zero Paint color
              Callie graphics almost done. As the original plane is not exactly the same as the AL37, I need to adjust my (bad) work with the decals and I recontacted Callie. But my work does not do justice to Callie's work.
                • 4878
                LucB , Great looking bird. You are doing an outstanding job. Best, LB
                • MikeT
                  Here......Hold my beer.
                  • 1060
ID:	236489 Anyone found a close paint match for the white on this one? Even after being ridiculously careful I've got some touch up to do after removing the masking tape. It's not too bad but I need to deal with it.
                  Mike
                  • Will.patrone
                    • 23
                    • New Orleans, LA
                    Mike
                    I have found the paint out of the factory to be terrible. I re-sprayed it. I would mask off your gray on the belly and repaint it.
                    • avanti127
                      • Apr 2018
                      • 96
                      Mike
                      I have the HD code at home. Will post tonight.
                      • urrl
                        • Oct 2013
                        • 508
                        • Heli143
                          Heli143
                          • 72
                          • Phenix City, AL
                          Love that video!! Thanks for sharing!
                          Roy Mayoral
                          • MANFRED
                            Any Warbird, any time
                            • 299
                            • San Diego, Ca
                            Ready for maiden.
                            • joeyj325
                              • 8
                              Awacs mod is basically done. Just a few small details left and a maiden flight.
                                Just when I think I've seen it all with this model. Bravo Zulu to you joeyj325 !!
                                • MikeT
                                  • 1060
                                  Wow.
                                  Mike
                                    joeyj325 Just fantastic!!! Awesome! Best of luck on your maiden and beyond! Jerry
                                    • Slowflight
                                      • 60
                                      She is painted, I will wait about a week to apply the graphic !!!
                                        • Slowflight
                                          • 60
                                          I was going to wait a few days due to the humidity levels but the warm garage made up for it and I was itching to apply the graphics, but I will wait for a few days before I apply the clear.
