  • Well that certainly answers the question I had. Just curious - what was the combined weight of the two batteries?
    • 1450g for two 5000mAh batteries
      • Originally posted by urrl View Post
        My HobbyStar 5200 are just over 1200 grams paired.
        • Originally posted by avanti127 View Post
          Do you have a link? They are heavier than mine on Amazon. What is your C rating?
            https://www.amazon.com/HobbyStar-520...614291&sr=8-17
            They are 45C. They are both around 610 grams each.
            • I worked on mine. Foam filler at the fuse junction, sanded wet with 2000, then repainted white with acrylic (paint for kitchen and bathroom from DIY store, 2 light layers with sanding in between). Silver is from foam paint can, grey is from Zero Paint color
              Callie graphics almost done. As the original plane is not exactly the same as the AL37, I need to adjust my (bad) work with the decals and I recontacted Callie. But my work does not do justice to Callie's work.
              • LucB , Great looking bird. You are doing an outstanding job. Best, LB
ID:	236489 Anyone found a close paint match for the white on this one? Even after being ridiculously careful I've got some touch up to do after removing the masking tape. It's not too bad but I need to deal with it.
                  Mike
                  • Originally posted by MikeT View Post
                    Mike
                    I have found the paint out of the factory to be terrible. I re-sprayed it. I would mask off your gray on the belly and repaint it.
                      Mike
                      I have the HD code at home. Will post tonight.
                        • Love that video!! Thanks for sharing!
                          Roy Mayoral
                          • Ready for maiden.
                            • Awacs mod is basically done. Just a few small details left and a maiden flight.
                              • Just when I think I've seen it all with this model. Bravo Zulu to you joeyj325 !!
                                • Originally posted by joeyj325 View Post
                                  Wow.
                                  Mike
                                  • joeyj325 Just fantastic!!! Awesome! Best of luck on your maiden and beyond! Jerry
                                    • She is painted, I will wait about a week to apply the graphic !!!
                                        • I was going to wait a few days due to the humidity levels but the warm garage made up for it and I was itching to apply the graphics, but I will wait for a few days before I apply the clear.
