Official Freewing 90mm Eurofighter Typhoon EDF Jet Thread
  • Hurridriver
    • Mar 2020
    • 8
    Help reqd. Having a brain fart moment and need confirmation, having moved the reciever and control board back on my Typhoon Ive plugged everything back in and check its working, which it is, but Im getting confused over the way the canards work. When you apply up elevator do the front of the canards go up or down. I should know this but............................Thanks in advance
    • BenOzzy94
      ground magnet extraordinaire
      • Jul 2020
      • 98
      • Kerry, Ireland
      Easiest way to think about it is a canard delta pitches through the air as if the control surfaces are running inside a bowl
        • 5385
        They go up. Up elevator front of canards go up.
        • DCORSAIR
          • 1918
          • Selma, Ca.
          I think of it the easy way, I look at the trailing edges of the control surfaces, opposite of each other...
          • Gravythe clown
            • Mar 2019
            • 711
            • Clovis, California
            V for victory. up = V, down = /\
            Gravy
            • SixOne
              Swooosh!!!
              • 43
              Customized my "Dual Personality" Motion RC 90mm Eurofighter....
              Mildly-Aggressive or Ferocious!!!
              Your intercept approach dictates the personality response....​
              • viper1gj
                • Feb 2020
                • 81
                I got the last of the decals on the tail and fin and added turbine wheel lines to fuse. The back line is supposed to be red but I didn't have red so it is black. The whole jet was given 2 coats of flat Polycrylic to take the sheen off the vinyl and give everything the same finish. Anyway its all done and ready to fly again.
                • viper1gj
                  • Feb 2020
                  • 81
                  Duplicate post removed
                    • 2691
                    Wow, lots of great liveries on this one. So I'll throw my hat in as well. Finally finished my "Bronze Tiger" Eurofighter. This one was extremely tedious for me , but it definitely is highly visible. It's the 8S version and I'm flying it on 2 HiV SMC 4S 4400's. The quality of the foam and hardware is certainly one of their best, I'm very impressed with it. Finished it off with 4 coats of clear gloss Spar Urethane which gives it a nice shiny hard surface.
                    Click image for larger version  Name:	20230531_180203.jpg Views:	0 Size:	164.4 KB ID:	380281Click image for larger version  Name:	20230602_171013.jpg Views:	0 Size:	130.1 KB ID:	380282Click image for larger version  Name:	20230621_173858.jpg Views:	0 Size:	385.0 KB ID:	380283Click image for larger version  Name:	20230621_174102.jpg Views:	0 Size:	364.0 KB ID:	380284Click image for larger version  Name:	20230621_174642.jpg Views:	0 Size:	297.8 KB ID:	380285Click image for larger version  Name:	20230621_180417.jpg Views:	0 Size:	262.4 KB ID:	380286 Click image for larger version
                    With it's twin brother from another mother:
                    Click image for larger version  Name:	20230621_183227.jpg Views:	0 Size:	151.2 KB ID:	380288Click image for larger version  Name:	20230621_183319.jpg Views:	0 Size:	148.4 KB ID:	380289
                      • 5385
                      Looks great as always Hugh.
                      • viper1gj
                        • Feb 2020
                        • 81
                        Wow, lots of great liveries on this one. So I'll throw my hat in as well. Finally finished my "Bronze Tiger" Eurofighter. This one was extremely tedious for me but it definitely is highly visible. It's the 8S version and I'm flying it on 2 HiV SMC 4S 4400's. The quality of the foam and hardware is certainly one of their best, I'm very impressed with it. Finished it off with 4 coats of clear gloss Spar Urethane which gives it a nice shiny hard surface.
                        Wow, that thing is awesome! How did you put on the black and white stripes and get the green graphics in the black stripes?
                        Gary
                          • 2691
                          Gary
                          Callie did the graphics for me which had the green eyes and black with white areas where needed, including the tail & canards. Although about 1/2 of the stripes are my own painting (mostly on the bottom and armaments) so it would look like the real Bronze Tiger and since I like a lot of tiger stripes.
                          This is the real version, and the only thing I did a little different was have the orange blead into a yellow on the canards, tail and outside wingtips:
                            • 2691
                            This is what Callie's graphic sheet looked like: I actually got 2 sets (6 huge pages in all) so I would have extra stripes or in case I messed up (quite common for me). Still had to do a lot of hand painting with gloss black to finish off the stripes and virtually the entire bottom is hand painted. The graphic sheets looked like a puzzle in hieroglyphics and I can honestly say I never really solved it more than maybe 50%.
ID:	380317Click image for larger version
                            • viper1gj
                              • Feb 2020
                              • 81
                              Nice work! After doing just my simple graphics I know it was a lot of work. Gary
                                • 2691
                                Short video on the maiden of the "Bronze Tiger". This aircraft flies exceptionally well and lands smoothly. They did a great job with this one!
                                  • 4819
                                  ...maiden of the "Bronze Tiger".
                                  Hugh, she is a marvelous flyer and one good-lookin' aircraft. Bravo Zulu, Sir. Best, LB
                                  • kallend
                                    • 1859
                                    Nice nozzles.
                                      • 2691
                                      Originally posted by kallend
                                      Nice nozzles.
                                      Yes they are quite outstanding. Clearly created by the "Master Designer"! Thanks for making them available on Thingiverse.
                                      • Fastjet57
                                        • Jul 2023
                                        • 5
                                        Hi all. I'm thinking of getting the Freewing Eurofighter Typhoon but I think I want to chose my own EDF and ESC so I'm thinking ARTF. Before I take the plunge I could do with understanding how to install the EDF/ESC and 'seal' the model back up for flight. I've seen the PnP manual online but it obviously doesn't cover EDF/ESC fitting. Does anyone know if there is a ARTF manual out there I could download and peruse? Cheers in advance. Phil.
                                          • 5385
                                          It’s easy, hatch on the bottom. I’m sending you a private message.
