  • downwindleg
    • 1279
    • Friday Harbor, Washington
    Originally posted by Pogo
    Video of it going up and down, up and down is up!
    Tom
    Tom, dude, that canopy operation is off the charts!!!! Looks like the real deal!! I congratulate you on a job well done. I'm gonna have to get measurements and geometry for that.......or a mailing address for my canopy/hatch to send to you. :)
    Brad
      Originally posted by bill34207
      I'm guessing the same thing that happened to the upgraded struts that were supposed to have been here mid September and again mid November. :pop
      Alpha said on 10/28 that they were expecting them to ship in 2-3 weeks and would list them after they shipped, that doesn't put them here by mid Nov so be patient ;)
        Originally posted by Topshot19
        found this scheme. I dont think anyone else has gave this one a try yet. Its called Flipper, close the the Alaska scheme. but different. I like it!
        Been done ;) But go for it :Cool:
        • Topshot19
          Pilot
          • 189
          • logan utah
          Oh oh well !
          • bill34207
            Jet Junkie
            • 455
            • Bradenton, Florida
            Actually 2 weeks from 10/28 would be mid November and in 2 more days it will have been 4 weeks since then. Since they are not listed yet, I'd assume they have not shipped yet.
              Good assumption and when they do ship they'll take a couple months(unless expedited) so hang loose and work on another project :Goodbye:
              • Dustman
                • 81
                Pogo, do you have move info and pic's on your canopy mod??
                • Tsmith
                  Flying since 1983
                  • Oct 2016
                  • 47
                  • Hancock, Mass.
                  Originally posted by buffetbob
                  Has anyone had a problem with the elevator servo or any other one fully deflecting during flight? I had my right elevator servo go full up during my flight and it still does. I got lucky and go her down in one piece but upon looking I was amazed that the elevator was full up.
                  I had the same issue with my right elevator...luckily I discovered it on the ground. The servo completely locked. I ordered a replacement servo from MRC and haven't had a problem since.
                  • Topshot19
                    Pilot
                    • 189
                    • logan utah
                    Practicing weathering/ painting for my a10. I’m using pan pastels which is a chalk of sorts. Anything I could spray over it to keep it from smearing ? And any tips on the weathering ?
                    • Shirty
                      Hobby Squawk Water Boy
                      • 1067
                      • Perth, Australia
                      Someone with more experience might chime in, but I believe best bet is a coat of minwax polycyclic or similar to seal it all in and stop smearing etc. works great on mine.
                      • fhhuber
                        • Aug 2015
                        • 1476
                        Do a sample test paint on a scrap of broken airplane... then try the clear matte finish on top.
                        I expect you will be better off with a spray so you don't smear the pastels with brushing.
                          I have been using either Testors Dullcote or Model Masters Flat Finish on my birds after detailing. Not only does it protect your detailing work, it also knocks any glossy sheen off decals and helps seal the factory paint.
                          • Calla
                            Ding
                            • Jun 2017
                            • 13
                            • San Diego, CA
                            Are you airbrushing the Testors Dullcote or the Model Masters Flat finish paints?
                            • mavdriver
                              • 38
                              • Hesperia , California
                              Hey guys why is it I don’t received email that someone posted on this thread I’m totally subscribed I’m subscribed to rc groups and I always get emailed when somebody post !
                                • 8835
                                I had that problem a little while ago. I posted it in the feedback thread: https://www.hobbysquawk.com/forum/mo...king-read-this
                                Someone did something to my account and it all works now.
                                  No, I'm buying it in the 3oz spray cans. The Testors is #1260 Dullcote, and the Model Master is #196003 Lusterless (Flat) Lacquer Overcoat. Just to be clear, these are clear lacquer overcoats, not actual paint.
                                  • themudduck
                                    -TMD- Foaming at the Mouth!
                                    • 1041
                                    • Burton OH (near Cleveland)
                                    So hey, I've been working on my A10 cockpit. Pogo's working canopy just blew me away, I can't believe how cool that is. I wanted to just quit!! But I went ahead and finished my little project up, it took me about two weeks worth of evenings.
                                    This summer I kept my bird out of the sun when it wasn't flying, but the foam inside the cockpit did alligator anyway, just from flying. The sun is powerful....
                                    So here's what I did to fix it:
                                    Removed the clear canopy by carefully peeling it off in one piece
                                    Removed the entire seat by cutting around the edges (this piece was glued in separately by the factory)
                                    Carefully sliced off the other three things behind the seat
                                    Cut out the two holes in the rear deck and cut out the floor of the cockpit, then inserted a very thin layer of black open-cell foam (this will allow air to circulate)
                                    Added paper decals for the side instrument panels and the center console
                                    Added a control stick
                                    Removed the HUD panel and side braces
                                    Sanded all the alligatored surfaces flat, then covered all of them one part at a time, with white cardstock, including the seat. This took a long time.
                                    I used some foam-filler to fill the cardstock-edges around the seat pieces
                                    Painted all the cardstock, and the rest of the interior a dark gray
                                    Reinstalled the bits behind the seat (they're covered in cardstock as well, except for the round thing)
                                    Reinstalled the HUD panel and side braces
                                    Glued the top back on (tonight)
                                    Yaaaaaay. it turned out OK. But it doesn't open. <sigh> And the pilot (Douglas Bader) has no knees.
                                    Click image for larger version  Name:	20171130_212450.jpg Views:	1 Size:	99.9 KB ID:	106467
                                      It looks really good.... Well done!
                                      • Porkster
                                        • 290
                                        • Suffolk, UK
                                        Definitely a big improvement over the standard foam interior mudduck :Cool:
                                        • Pogo
                                          • 452
                                          • Waterford, Ontario, Canada
                                          Duck, the heavily 'gatored cockpit foam made me cringe all summer long- yours looks soooo much better now! :Cool:
                                          Tom
