  • Warthog
    • Feb 2020
    • 119
    • Crockett, TX.
    Does anyone make those aluminum plates for the retracks? I could makes them myself, but I would gladly pay for a set. Thanks.
    • coydog73
      • Mar 2020
      • 6
      question I have the motion rc f18 90mm and I bought the f16 ordnance to put on my f18 but there is no videos or directions on installing this on my plane has anyone done this or made a videos
      • Waconut
        • Feb 2020
        • 310
        • Cincinnati, Ohio
        I painted the top side yesterday and today I went over all the panel lines and rivets with a black mixture in the airbrush. After that was dry I went back over those areas with the base color. I like the effect, it is somewhat subtle. I still need to do the same treatment to the bottom.
        • scootergenie
          Jet lover
          • 261
          • Stuart FL.
          Looking sweet so far. There's a fine line between not enough, and overdone.
            This is so true and cannot be overstated enough. I see so many weathering jobs that are unrealistic because they didn't know they crossed that line of overdone before it was too late. It's very easy to do. But with weathering, if scale realism is what you are after, I always tell people "less is more."
            • scootergenie
              Jet lover
              • 261
              • Stuart FL.
              Last month I attended the e jet fest in Mulberry, Florida hoping to take home best static scale jet with my 70mm F16. There were 2 top gun judges inspecting our planes. One of them said that a lot of the planes at top gun are way overdone. Anyway, I was told that some of those guys at top gun could take lessons from my weathering job, so I felt good about that ! However, I missed the mark on details, and walked away with runner up. No matter how good the weathering job is, it's only a portion of the total score. I'll do better next year.
              • WrightBrosRC
                All Things Aviation
                • Feb 2019
                • 195
                • Hillsboro, OR
                Hi Guys! I was attempting the maiden flight yesterday and something very odd happened. I increased throttle and started the roll out and at near rotation, a loud popping sound. I shut it down and rolled off the end of the runway. Inspection reveals the white plastic part to have come unglued and the spring loaded gear door ripped from its very thin plastic trunnion hinges.
                Gear pre-flight retract and extend with no issues. Smooth runway.
                There is travel in the retract servo now which may be from running into the grass at the end of the runway. Likely bent trunnion pin, but mowed grass should not do that at landing speed. I'm fortunate I didn't take off.
                I'm not sure what to think about this?
                Any thoughts?
                Thx
                Den
                  • 8835
                  That triangular white plastic piece has been known to be poorly glued to the gear door. Several reports of this early in this thread. Even just rolling down the runway has caused it to fall off. Most of the time, it doesn't harm anything. Unfortunately in your case, it got caught on other stuff and ripped off, creating further damage to associated bits and pieces. I've had it happen twice. The first time, no damage but I didn't use the proper glue and it fell off again a few flights later. The second time, it did the damage to mine as it did to yours. I did manage to repair the part that has the holes in it but that didn't last. I purchased a complete new part (with the holes) and it's been good since.
                  • Waconut
                    • Feb 2020
                    • 310
                    • Cincinnati, Ohio
                    I painted the camo pattern on the A-10 today. It didn’t turn out like I had envisioned or planned but I will take it. It should still look Bad A$$ once the weathering is complete and the decals are applied.
                      • 4875
                      WN, Looks 'Outstanding' from here, Sir. Best, LB
                      • scootergenie
                        Jet lover
                        • 261
                        • Stuart FL.
                        I like it !
                        • Waconut
                          • Feb 2020
                          • 310
                          • Cincinnati, Ohio
                          Hi guys,
                          I started applying the graphics that I received from Callies and I must say they are great. Anyhow has anyone used her graphics and applied the Sharks mouth? Any pointers would be appreciated I would hate to screw them up.
                            • 4875
                            Hi guys,
                            WN, did you have Callie Graphics supply you with the 'Sharks Mouth"? I ask only as I had her do the Shark's Mouth for my Freewing F-4 in 2 sets of each different color and used some for 'outline templates' and others then for application. Worked well using the White paint for the large compound curved area and then the Red graphics and striping for the other colors. Best, LB
ID:	241899Click image for larger version
ID:	241900Click image for larger version
                            • MikeT
                              Here......Hold my beer.
                              • 1060
                              Hi guys,
ID:	241904Click image for larger version
ID:	241903Click image for larger version
                              It's water-slide. take your time. I found that Micro -Sol and Set made a huge difference on how the decal set down. Worked great.
                              Mike
                              • Waconut
                                • Feb 2020
                                • 310
                                • Cincinnati, Ohio
                                LB,
                                Yes Callie supplied the Sharks Mouth.
                                Mike,
                                I am using vinyl graphics supplied by Callies Graphics. I am not using the stick water slide decals.
                                Thanks!!
                                Anthony
                                • MikeT
                                  • 1060
                                  LB,
                                  Mike,
                                  Thanks!!
                                  Anthony
                                  Use the watersilde that came with the A-10 from Motion. I used most of Callie's stuff but not the vinyl shark mouth.
                                  Mike
                                  • Waconut
                                    • Feb 2020
                                    • 310
                                    • Cincinnati, Ohio
                                    I will try the vinyl first. I hate water slide decals.
                                    • MikeT
                                      • 1060
                                      Keep us posted.
                                      Mike
                                        • 8835
                                        As much as I dislike waterslide decals, at least for a curvy surface and a relatively large decal, they go on better, can be slid around and can conform to odd lumps and bumps better. If it doesn't work out, don't completely blot out all the water and you can soak it all down more and it comes off fairly well. Vinyl, on the other hand, once it makes contact and sticks (even mildly on a small spot), is a bugger to lift off and relocate. Lifting off a vinyl decal can sometimes take paint with it. Callie Graphic decals are high quality but they have really good "stickem" and the vinyl is much thicker than a waterslide due to the backing on the top side.
                                        • Warthog
                                          • Feb 2020
                                          • 119
                                          • Crockett, TX.
                                          QUESTION! I have a Hobby Eagle Super 3 stabilizer and when I activate my home made "gun sound" motor, it vibrates the fuselage, just like a transducer would with a Mr. RC Sound system. I'm getting a fair amount of aileron,
                                          rudder and elevator flutter!! Any suggestions? I'm thinking about buying the Mr. RC system, but first I want to make sure this won't happen with it. Thank you Sir.
