  • Warthog
    • Feb 2020
    • 119
    • Crockett, TX.
    If anyone sells this unit, I'll take one! Here is my pilot almost finished:
    • Warthog
      • Feb 2020
      • 119
      • Crockett, TX.
      Does any one make an oxygen mask hose that's flexible?
      • Waconut
        • Feb 2020
        • 310
        • Cincinnati, Ohio
        You will probably have to make your own. I would look at 12 ga. strand wire. Pull the wire out of the rubber sheath and paint the sheath to the proper color. Just a thought.
        • Warthog
          • Feb 2020
          • 119
          • Crockett, TX.
          Thats a great idea!! I thought of using wire, didn't think of pulling the strands out. Thanks!
            • 4877
            WH, Don't know which pilot figure you are using, but for example, the O2 hose with the Jet Hangers Hobby pilot is flexible after soaking it in 'HOT" water. Best, LB
            • Warthog
              • Feb 2020
              • 119
              • Crockett, TX.
              I need it flexible all of the time, for this: https://www.youtube.com/watch?v=LCSeEMEVvKE The wire insulation idea worked FANTASTIC!
              • Hoomi
                Cactus Dodger
                • Apr 2018
                • 863
                • Baja Arizona
                When I made the O2 hose for the pilot in my 64mm A-10, I used heat-shrink tubing. It comes in many sizes, and you shrink it around a piece of soft wire or something similar, if you want to shape it. It also is easy to form while it's still warm.
                • Waconut
                  • Feb 2020
                  • 310
                  • Cincinnati, Ohio
                  WH needed it to stay flexible, his pilots head moves left and right. He has a video link in his post.
                  • Warthog
                    • Feb 2020
                    • 119
                    • Crockett, TX.
                    My first "weathering" a plane. I may have over done it a bit. But I still like it! LOL Thank you for the pointers lmramos44 !!Click image for larger version  Name:	IMG_0846.jpg Views:	7 Size:	79.8 KB ID:	246663Click image for larger version  Name:	IMG_0849.jpg Views:	7 Size:	83.8 KB ID:	246666Click image for larger version  Name:	IMG_0847.jpg Views:	7 Size:	60.7 KB ID:	246664Click image for larger version  Name:	IMG_0848.jpg Views:	6 Size:	71.3 KB ID:	246665
                      Great job first timer!
                      • Warthog
                        • Feb 2020
                        • 119
                        • Crockett, TX.
                        Thank you very much!!
                          • 4877
                          WH, I don't believe you can 'over do it' on an A-10. Looks great, Sir. Best, LB
                          • Warthog
                            • Feb 2020
                            • 119
                            • Crockett, TX.
                            Thank you Elbee. Your right, if it isn't worn and dirty looking, it's not a HOG!! LOL Kind of like in the Harley world, if it's worn and dirty, it's called a RAT BIKE!!
                              Bored with quarantine so I took the first photos of my two current Arctic Camos (FW 90mm F-16, FW 80mm A-10) in my hangar. I wonder what they talk about at night?
                              • Waconut
                                • Feb 2020
                                • 310
                                • Cincinnati, Ohio
                                Sweet!!!!!!
                                  • 2137
                                  • On planet earth....right
                                  Looks awesome, Aros!
                                    • 4877
                                    So an F-16 and an A-10 roll into a bar and the A-10 says, "Hey, nice suit." and the F-16 says, "Yeah well, it's comes with the territory." Bah-dum-tss, LB
                                      Thanks gents and LB...
                                      • scootergenie
                                        Jet lover
                                        • 261
                                        • Stuart FL.
                                        I really like your A10 Aros !
                                        • Warthog
                                          • Feb 2020
                                          • 119
                                          • Crockett, TX.
                                          Question!! Has any one changed out the stock tires for a set of "Low Bounce" tires? These stock tires develop BIG flat spots after sitting awhile.
