View Post
Another way to address *only* the non-UBEC-ESC might be to plug the throttle cable for the UBEC-ESC into a different Rx channel, so it is powering the Rx, but not receiving throttle. For example the bind port has the signal wire weakly pulled high, weak enough that it can be pulled down by a bind plug, but when connected to a high-impedance input like the ESC throttle wire, it will be solid high. So it would have no pulses on it. Or you could use some other channel like the gear channel, and keep the gear switch set so that it looks like low throttle to that ESC. Then you can connect the actual throttle signal only to the non-UBEC-ESC, and program or range-set that ESC by itself.
