    • Nov 2013
    • 2783
    • Cody, WY
    Thanks, Aros. Happens to the best of us, sometimes. It did fly and land great, especially after I changed out the stock main wheels for the 3.5" Robarts. It really helped "stick" the landings!
    My new plane will hopefully look just like this one, maybe add some extra detailing. I did add little bits like the trim tab and balance tab rods that you can barely see on the horizontal stab/elevator in the picture. I like messing with little details like that, although most of them go unnoticed by others.
      Those "little details" may be missed by some but us Corsair Comrades certainly don't. Way cool added scale touches!
        • Nov 2013
        • 2783
        • Cody, WY
        There was no doubt that people like you would appreciate details like that! Thank you for noticing.
        I probably added them to demonstrate the genius of Chance Vought and his team of engineers who designed the horiz. stab/elevator assemblies to be totally interchangeable (L or R side of the fuse). You can see even on the model that on one stab unit, you'll see the circular inspection panels on the top of the stab, and the other side they are on the bottom. Came in pretty handy when shipping these parts to remote parts of the world like the South Pacific where they would appreciate just one unit fits for both sides!!
        Lots of other equally impressive headwork designs demonstrated by the Vought team of engineers!!
        davegee
          • 2716
          My favorite Corsair landing photos, not quite as good as hitting a 3 pointer like you did with the F-16, but close. At least I got this part of flying the Corsair "scale" down pat.
          Click image for larger version  Name:	C4-rfVGXAAA7NI9.jpg Views:	0 Size:	101.8 KB ID:	312705Click image for larger version  Name:	F4U.jpeg Views:	0 Size:	100.9 KB ID:	312707Click image for larger version  Name:	sPsCiBEVBBchz3XBYfE-q4Y9fsDYQLlXg9Kl4Po15bE.jpg Views:	0 Size:	129.3 KB ID:	312706
          • f4u ausie
            • 1242
            • Melbourne
            been away 4 a bit guys,,,.. awsome pics and 3 d printed stuff goin on.... been thinkin bout a down mix at full flaps 4 landing,, wana get better at the 2 wheel landings..... have been dumb ar?.s with radio programming.... think ive got it down now.... question is how much down at full flaps.. in mm please im think8n a couple hope i dont tip stall it again ,,, gota keep some power coming in...
              • 2716
              At the risk of sounding like a broken record, try using Flight Modes (definitely available on a Spektrum TX-but not sure about others) to make trimming elevator with flaps so much easier instead of programming a mix. Still set your expected elevator compensations in the Flap System settings, but by enabling Flight Modes, you can fine tune the trim while in flight for each flap settings for whatever air speed you want and whatever attitude you want the plane to be at. These trims remain for each specific flap positions without having to guess on a mix. For a quick set-up guide go to my post in the Official F-18 Hornet thread and go to post #4951. Takes about 30 seconds to set up the TX, then one flight to trim exactly the way you want it. And of course you can always fine tune it or change it "on the fly". One of the top 3 TX programming tools, IMO, if you are flying an aircraft with flaps (or even flaperons)!
              • Balsa Bob
                • Sep 2020
                • 59
                • New Hampshire
                Hope to maiden mine this weekend .... all I have left to do is balance it. When using a 6S 6000 mah pack, are any of the weights still needed in the cowling ?
                Thanks. Bob
                • f4u ausie
                  • 1242
                  • Melbourne
                  Thanks. Bob
                  4 me zippy 6200 2 weights and battery all forward .. i think its 830 grams
                    How to make these feel really small! But man this was such an awesome day at round top today. Some absolutely beautiful planes! PS mine is center left. In the pic obviously, the smallest plane in the pic. Lol
                    • f4u ausie
                      • 1242
                      • Melbourne
                      Wow warbird heavan.. value 4 the doller that small little foamie in the middle packs an awsome punch:partying_face:
                        Yes indeed!
                          Cool pic!
                          Sign me up for a 2000mm version someday, PLEEEEEASE!!!
                          • Tigerman
                            • 62
                            Anyone tell me what compensation I will need for 20mm of flaps.Not sure how much elevator compensation I will need for 20mm of flaps on landing and if I will need up or down compention on the elevator?
                            • ICM
                              • Oct 2017
                              • 226
                              Do a search on this thread for "flap elevator mix". Most say its not necessary. Some say it helps to avoid bouncing on landing and give specific settings.
                                • 8830
                                Elevator compensation depends on how you fly and how and at what time you deploy them. This plane will "balloon" (ie, go up) if you deploy flaps at too high an airspeed or too rapid deployment. If you wait for your plane to slow down first and deploying the flaps slowly (like on a real plane), no elevator compensation is required. You can easily deal with whatever (if any) ballooning that occurs. If in doubt and if you are one of those who slams the flaps down rapidly at high airspeed, then start with 10% for full flaps and go from there (higher or lower). Deploy them up high so you have time to un-deploy if the plane goes weird. You will likely find that with full flaps and ELE compensation, that as the plane slows down in preparation for touch down, that comp is unnecessary and will have to manually un-compensate for the compensation. This, plus too slow a landing speed (due to the flaps) has caused many a crappy landings (and/or crashes). Everyone is different as to when and how to deploy flaps, there is no set number. I use zero ELE comp.
                                • Tigerman
                                  • 62
                                  Thanks for your advice XVIPER. I will do that thanks again
                                  • Arycon
                                    • 137
                                    • Melbourne, Florida
                                    Second this. I used a 6S 6000mah Admiral Pro pack. 2 weights. All the way forward
                                    • Skosh25
                                      • Mar 2019
                                      • 177
                                      • Denver
                                      Following up from last week, here’s my finished repaint of the XF4U-1 prototype Corsair, which first flew 29 May 1940. My Flightline Birdcage Corsair first flew May 2019 and has over 200 flights to date. Motion RC
                                        Mine is flying very well as is out of the box with 4000 mah packs
                                          • 4869
                                          Originally posted by Skosh25
                                          Following up from last week, here’s my finished repaint of the XF4U-1 prototype Corsair...
                                          S2, that is just so cool. Great repaint. Best, LB
