  • Clugh
    Current F3A world champion American motor winder.
    • Sep 2023
    • 5217
    • Research Triangle Park North Carolina
    It was also already damaged when you connected it to 6 s lipo. :clown:
    State-of-the-art PMSM/BLDC motor control solution for aerospace applications and robotics - Télega - Zubax Robotics​
    • Clugh
      • Sep 2023
      • 5217
      And this is just some of the reasons i dont listen to anything you say. You not honest partner.
      All that is left of the "dumm" 400 inverter is the other blown half and a navy you brought second hand. Sounds like things are working out with your machines and the inverters you are trying to run with them. U say they are only thing that will do for speedflying.
      Yeah no ones entering that $Port then.
      Good Luck
      Hubert
      • Clugh
        • Sep 2023
        • 5217
        The thermal behavior cannot be compared either, because, as described above, the temperature sensor is in an unfavorable position, and the whole thing is manipulated by the missing shrink tube.Thus, the regulator becomes permanently too hot, which explains the frequent failures.
        And that's just something that is often swept under the table.
        It is always said that the old 160s and 320s are so great. They went through it all.
        If you're honest, they just don't. I can see what I have to take back from Ballenstedt to the service every time.
        ~Marian YGE~
        • Clugh
          • Sep 2023
          • 5217
          You read this directly from YGE and still go buy an old navy YGE? Versus winding towards your opto 255 with new RCT cooling or a new navy which should be fine if you dont need 400 amps cont like you said.
          Boy you crazy....4 real...:bomb:
          Your head is made from bricks. I can't help you. U dont have sense to go get the newer controllers with better software and cooling designed by them.
          what test you gone run that they haven't.....
          Hubert
          • Clugh
            • Sep 2023
            • 5217
            Who does this if they want to run cooler? U need to be able to take advice from someone playa.
            Click image for larger version  Name:	100_3660.jpg Views:	0 Size:	162.9 KB ID:	414300 vs Click image for larger version  Name:	IMG_6175-1-300x225 (2).jpg Views:	0 Size:	12.3 KB ID:	414301
            • Clugh
              • Sep 2023
              • 5217
              Es ist lustig. Laut Brenner hat er geantwortet, aber helifreak muss seine Antwort plötzlich noch einmal durchlesen, bevor er sie posten kann. Offensichtlich hat sie es noch nicht ins Forum geschafft ...
              Crocoworld2
              Das Paar hier will nicht, dass der Amerikaner etwas verkauft hat.
              Danke, 🖤
              Hubert​
              • Clugh
                • Sep 2023
                • 5217
                Old 11-13-2024, 01:49 AM #5 (permalink)
                andysofly
                Registered Users
                Following. I would like to have a 4225 wound.
                Reply With Quote Quick reply to this message
                Old Today, 12:55 AM #6 (permalink)
                CHX2
                Registered Users
                Hi Andysofly,
                send you an pm about a adress for rewindig the motor.
                Happy Amps Christian
                ​Its over Ralph!!! I think you better find a better motor because antiquity in the inverter and motors wont yield you a thing into 2025. The knockers are just not it and we can get ready for another YGE to fail because of overdriving it.
                Ich habe nicht vor, dir weitere Tipps zu geben, weil die Idiotentruppe damit nicht klarkommt. Ihre riesigen PENTIUMs sind so langsam und voller Luft. Ich würde lieber einem Clan beim Untergehen zusehen.
                I can give you 10 candles but you cannot hold 1.
                Click image for larger version  Name:	a1566399-132-20220116_182223.jpg Views:	0 Size:	46.3 KB ID:	414337
                Please explain what good is a titanium shaft into a 5 dollar steel bearing that raises the idle current and lowers the rpm robbing efficiency. You're excited about that? People can decide for themselves if that sounds like the reasoning of an "expert" motor winder?
                True experts could design and build the gear drive they want.
                Go on home.
                Hubert
                • Clugh
                  • Sep 2023
                  • 5217
                  The little boys cannot build anything Here are my hand built 44 pin atmel and 18 pin PIC programmers. probably 25 years old.
                  Click image for larger version  Name:	20230303_090032.jpg Views:	0 Size:	200.5 KB ID:	414339
                  • Clugh
                    • Sep 2023
                    • 5217
                    Click image for larger version  Name:	20230323_084234.jpg Views:	0 Size:	126.7 KB ID:	414342
                    Where is the German social media on this? I had been building things like this for years before you ever touched an electric motor. Boy bye...these are connected with db25. parallel port. LOL pc's dont even come with that any more its so ancient. In electronics you are literally a child to me DR Ralph Okon. This is really my life and you are nothing but an electronics fraud to me.
                    Where is YOUR electrical engineering degree? I have mine.
                    :no_mouth:
                    Have a great day
                    Hubert
                    • Clugh
                      • Sep 2023
                      • 5217
                      The Importance of Bearings
                      Inside each spindle is a set of ball bearings that must hold very tight tolerances, withstand extreme conditions, and also last for many years. To accomplish all this, there are different types of bearings manufactured for very specific applications.
                      Two variations of ball bearings that inspire a lot of questions are ceramic vs. stainless steel. At Northland Tool & Electronics, we get asked quite often if we can “upgrade” steel bearings to ceramic.
                      Ceramic and steel ball bearings are very similar in design. The contact points, inner and outer dimensions, and thickness of steel and ceramic ball bearings are the same. The only noticeable difference in design is in the ball material — ceramic or steel.
                      The most significant differences between the two types are apparent in their performance and longevity — read on for details. Ceramic Bearings vs. Steel Bearings: Key Differences
                      Friction:
                      Ceramic balls are rounder, lighter, harder, and smoother than steel balls due to their lack of porousness. This reduces friction as well as energy loss, allowing your equipment to run more efficiently (and for longer) with ceramic ball bearings. Because of their relative smoothness, ceramic ball bearings require less lubrication than steel bearings.
                      Corrosion:
                      Steel balls will corrode over time, even with perfect lubrication, while ceramic balls do not corrode. In fact, ceramic hybrid ball bearings may last up to ten times longer than steel bearings when it comes to corrosion.
                      Bearing Races:
                      Ceramic balls have a much lower elasticity than steel balls, which is important to keep in mind when considering an upgrade to ceramic bearings. If you experience heavy spindle loads or spindle crashes, ceramic balls are more likely to cause damage (brinelling) to the bearing raceways. Over time the dents in the raceways grow larger and eventually lead to spindle failure.
                      Conductivity:
                      Ceramic bearings are non-magnetic and non-conductive, so they are often preferred in applications where electrical conductivity is a concern — for example, if you have an electric motor controlled by a variable frequency drive.
                      Precision:
                      When it comes to precision, the ABEC ratings of the spindle bearings we use are high enough that the difference between ceramic and steel bearings is minimal. The sole difference is that ceramic bearings will not thermally expand as much as steel bearings, and so will not generate as much heat at high speeds or have as much measurable thermal growth.
                      Cost:
                      This is typically the biggest difference between ceramic and steel bearings. Ceramic bearings are, on average, are 50% more expensive than steel bearings. As such, ceramic bearings are not always a cost effective improvement over steel bearings. When to Choose Ceramic Bearings vs. Steel Bearings
                      Ceramic
                      Ceramic bearings are usually considered for a spindle application in the following circumstances:
                      • A speed upgrade is needed
                      • Applications in which high loads, high speeds, and extreme temperatures are factors
                      • To modify the spindle to add additional axial and radial stiffness while maintaining its speed capacity
                      • In conjunction with a lubrication change to keep the speed capacity and remove oil mist systems
                      • When electrical conductivity is an issue
                      ~NTE~
                      So stay with the steel bearings Doc! Im also a certified machinist CNC and manual programmer operator and set up. I can do it all. CAD/CAM certified What can you do?
                      I have all my paperwork and state seals
                      Thank you.
                      Hubert
                      • Clugh
                        • Sep 2023
                        • 5217
                        Click image for larger version  Name:	003 (2).jpg Views:	0 Size:	84.8 KB ID:	414362
                        The cages are made from 350 maraging steel the needle are made form precision dowel pins. Ralph Okon and his friend don't know a damn thing about a ball bearing that's why this medical surgeon from Putin's place thinks hybrids are a joke. I know how to make these because James Allen taught me. James was who was honing Chroming and sleeving the Henry Nelson long strokes at Aero precision in Liberty , N.C. before he passed. As I understand Mike Langlois passed as well and just his sons are there now. I probably should contact them and Henry if he's still alive because people like Ralph Okon cannot teach me a damn thing about electronics or high level manufacturing. He does have a few capable friend there like his friend that CNC's his prop molds. Other than Ralph has not shown me anything to get excited about in years. Cleary he doesn't even really have an interest in electric motors because that alone would drive him to explore other things besides himself.
                        Die Käfige sind aus maragendem 350er Stahl, die Nadeln sind aus Präzisionspassstiften. Ralph Okon und sein Freund haben keine Ahnung von Kugellagern, deshalb hält dieser Chirurg aus Putins Haus Hybride für einen Witz. Ich weiß, wie man sie herstellt, weil James Allen es mir beigebracht hat. James war derjenige, der die Henry Nelson Long Strokes bei Aero Precision in Liberty, N.C. geschliffen und mit Hülsen versehen hat, bevor er starb. So wie ich es verstehe, ist auch Mike Langlois gestorben und nur seine Söhne sind jetzt dort. Ich sollte sie und Henry wahrscheinlich kontaktieren, wenn er noch lebt, denn Leute wie Ralph Okon können mir nichts über Elektronik oder hochwertige Fertigung beibringen. Er hat dort ein paar fähige Freunde, wie seinen Freund, der seine Propellerformen CNC-bearbeitet. Ansonsten hat Ralph mir seit Jahren nichts gezeigt, worüber man sich hätte aufregen können. Offensichtlich hat er nicht einmal wirklich Interesse an Elektromotoren, denn das allein würde ihn dazu bringen, andere Dinge als sich selbst zu erkunden.
                        Hubert
                        • Clugh
                          • Sep 2023
                          • 5217
                          Das Ärgerliche an Christian ist, dass er ein deutscher Ingenieur mit ähnlichen Fähigkeiten in verschiedenen Bereichen ist. Ein echtes Genie, wenn es um Elektronik und alle Arten mechanischer und chemischer Geräte geht, aber er verschwendet viel Zeit damit, es Arschlöchern zu geben, die es nicht wollen.
                          Jetzt habe ich noch Dinge zu tun und melde mich später bei Ihnen.
                          Vielleicht​
                          Danke
                          Hubert
                          • Clugh
                            • Sep 2023
                            • 5217
                            Wenn er alles weiß und nichts Neues lernen will, warum verschwende ich dann meine Zeit damit, ihm etwas beizubringen? Die Götzendiener mögen mich nicht, weil ich seine Theorien infrage stelle und dies auch weiterhin tun werde.
                            • Clugh
                              • Sep 2023
                              • 5217
                              Christian,
                              I ordered the Super chief from I-care days ago. The planetaries cant have the best bearings because there are bearings in the relevant sizes that may cost as much as the entire planetary drive alone so any of them can be upgraded by the capable. I wished I had order the gearbox factory direct because there is just a recording at the place when you call and the people say they wont be shipping out till the 30th. I would have had the gearbox by now factory direct. But I will order a P32 or P42 from Steve tomorrow and when I get it I'll show you what's there. I guess I can also order the firewall mount and wind the 3225 pyro for the Super chief 4:1 planetary gear box and pop it in ze plane.
                              Click image for larger version  Name:	My Plane.png Views:	3 Size:	1.58 MB ID:	414373
                              If the good lord blesses me for Christmas, daddy gets a new 18 channel Futaba
                              • Clugh
                                • Sep 2023
                                • 5217
                                Click image for larger version  Name:	image.png Views:	0 Size:	83.7 KB ID:	414385
                                I want the boys to see what helifreak did. Since Christian has been a member since 2016 his message got immediately through then they decided to let Brenners message that was two days older than Christians through. It pops up in the early AM. in the right chronological order. If Christian wouldnt have posted that Brenners post would have never come through. They banned me for straightening two modelers that know absolutely nothing about motors or inverters and Im still at the top of the winding pages there. The real reason is this Rick cant 3d print and he's mad i corrected him on the site about the necessity of drying the filament. Because he was a moderator he was supposed to be smart. They also fly Ralph. Ha! His prints on a 2000 3dp dont look any better than mine off a 350 dollar ender tuned by me. Real talk.
                                Click image for larger version  Name:	20220110_123607.jpg Views:	0 Size:	147.3 KB ID:	414390
                                From day 1 they had an issue I didn't bow down to Ralph supposed expertise in subject matter I was formally trained. Unlike he or them.
                                Either way they know where to find me now Ralph....
                                You can expect some real data and feedback on a 4225 wound by Clugh.
                                Im banging out of research triaingle park NC where there are more PhD's per square mile than anywhere else in this country.
                                Powercroco is the number 1 spectator here in this thread and that's a fact. I couldn't type two sentences before he was signed up and following me here.
                                ​Id like to share here a few things about electric motors and inverters that I have been exposed to over the years. Hope there will be interest here (filedata/fetch?filedataid=91738) ​ Thank you. THE REAL 1BOHO.
                                I dont really have any issue with Scorpion except that they let this green garden dwarf spread lies about their motors that even they dont all over our forums and he just wants another sale. You can goto scorpions site and get the truth about their engines. They post the data with no games. Scorpion was never the problem here. I own a few.
                                Get a Clugh....
                                Hubert​
                                • Clugh
                                  • Sep 2023
                                  • 5217
                                  • Clugh
                                    • Sep 2023
                                    • 5217
                                    Click image for larger version  Name:	5020 1.828mm.png Views:	0 Size:	655.7 KB ID:	414394
                                    HK 5020
Name:	slot wedge for 5020.png
                                    I already have slot wedges that fit it perfectly Ralph but there is enough room to tie in the wye motor on the empty teeth I can get prolly 4 turns there. That will be quite alot of 1.828mm copper conductor (13 or 14T). This is 13 AWG! This can also be run in the dual inverter LRK or DLRK setup that really reduces the bell temps. It doesn't matter. When its complete Id love for anyone to compare it to Ralph 5020's
                                    Click image for larger version  Name:	20231126_152717.png Views:	0 Size:	473.2 KB ID:	414395
                                    German:
                                    Ich habe bereits Nutkeile, die perfekt passen, Ralph, aber es ist genug Platz, um den Sternmotor an den leeren Zähnen zu befestigen. Ich kann da wahrscheinlich 4 Umdrehungen machen. Das wird eine ganze Menge 1,828 mm Kupferleiter (13 oder 14T) sein. Das ist 13 AWG! Dies kann auch im Dual-Inverter-LRK- oder DLRK-Setup ausgeführt werden, das die Glockentemperaturen wirklich senkt. Es spielt keine Rolle. Wenn es fertig ist, würde ich es gerne mit Ralph 5020 vergleichen.
                                    Kein bifilarer Blödsinn
                                    Danke
                                    Hubert
                                    • Clugh
                                      • Sep 2023
                                      • 5217
                                      Gefühle seiner Freunde und Fans nicht verletzen, aber Ralph kann mich nicht schlagen. Es tut mir so leid, dass er etwa 25 Jahre zu spät kam. Wenn ich etwas für Ballenstadt zusammengestellt hätte, hätte keiner von euch den Mut gehabt, es fliegen zu lassen, weil ihr euch schon Sorgen über das Ergebnis im Vergleich zu ihm macht.
                                      you see he is here
                                      Boho1
                                      Today, 05:17 AM
                                      Viewing Forum​
                                      Danke,
                                      Hubert
                                      • Clugh
                                        • Sep 2023
                                        • 5217
                                        F3B-E wrote:
                                        But just write to this company (link below) with your request to. I think they can help you. Since most of the gears come from here.
                                        IMS Gear: Our planetary gears
                                        IMS Gear is one of the leading companies in gear and transmission technology – internationally positioned, a partner to globally active customers and consistently innovative. We implement both standard components and complete gearbox solutions (including planetary gearboxes) at the highest level – from the...
                                        www.imsgear.com
                                        If you look at the data sheets for the 4:1 gearboxes of this manufacturer, you will find 0.8 for the efficiency.
                                        If this manufacturer has made honest statements, they explain the rather high heat development of the gearboxes.
                                        ~powercroco~
                                        Du weißt immer noch nicht viel, Ralph, denn die Effizienz der Getriebe bei der Leistungsstufe, mit der Thomas prahlt, ist mit dem Superchief sogar geringer als 0,8. Wenn du einen echten Taschenrechner benutzt hättest, statt den Mund deines Freundes zu benutzen, wüsstest du das wahrscheinlich. Du weißt auch, dass die Effizienz deines Motors etwa 0,8 oder 3 % geringer ist als die des Innenläufers, also werden deine Motoren deshalb so heiß wie ein Getriebe, aber dieses heiße Getriebe beeinflusst die Kommutierung von der Wechselrichterseite nicht so wie dein Motor? Es macht auch nicht die doppelte Durchsatzleistung der effizienteren Maschine gegenüber deiner aus. Ich hoffe, du verstehst das​
                                        You still dont know much Ralph because the efficiency of the gearboxes at the power level Thomas boast is even less than .8 with the superchief. If you used a real calculator versus your friends mouth Youd probably know that. You also know your motor efficiency is about .8 or 3% less than the inrunner so that's why your motors get as hot as a gearbox but that hot gearbox doesn't affect commutation from the inverter side like your motor does it? It also doesn't make up the 2 fold throughput power delivery of the higher efficiency machine over yours.
                                        I hope you can understand
                                        Thank you
                                        Hubert
                                        • Clugh
                                          • Sep 2023
                                          • 5217
                                          Why keep talking motor mouth?
                                          just wind up you direct drive motor you plan to compete with the gear driven Lehner. Get to it.
                                          Click image for larger version  Name:	7_0.webp Views:	0 Size:	6.5 KB ID:	414400
                                          We are waiting for your data,
                                          Hubert
