So yes load the 14 pole halbach that wont report its rmp, iq or id and the run less 20 pole with a prop or please just shut up! The theory did not pan out empirical. and it doesn't explain the slotless 2 pole machines torque delivery. No body cares about a know it all egg head with out an iota of data.
well the 14 pole he showed is not a steel flux wedge arrangement as he reported REMOTELY to me that is all pm.
The goal post change as usual. This is why i ask all the right questions first so he cant back track. What's the RMP of his Halbach machine.?If he wont report it i already told what kind words you can deliver coz he is wasting your time avoiding the relevant questions.
Nun, der 14-polige, den er gezeigt hat, ist keine Stahlflusskeilanordnung, wie er mir berichtet hat. Das ist alles per PN.
Die Zielvorgabe ändert sich wie immer. Deshalb stelle ich zuerst die richtigen Fragen, damit er nicht zurückrudern kann. Wie hoch ist die Drehzahl seiner Ibach-Maschine? Falls er sie nicht meldet, habe ich Ihnen bereits gesagt, welche freundlichen Worte Sie ihm schicken können, denn er verschwendet Ihre Zeit damit, den relevanten Fragen auszuweichen.
AND RALPH IS RIGHT ABOUT SCALE. JUST BECAUSE HE CREATED BUS MOTORS THAT DID WELL WITH THIS DOES NOT MEAN IT TRANSLATES DOWN TO 50MM CUT.
HE IS ABSOLUTELY CORRECT!!!! THE SPEED RANGES ARE ALSO VASTLY DIFFERENT!
I see I switched the narrative to "what's it optimized for"
Well sir.... their application is speed flight so max torque and rpm (POWER) with a six step drive. So where would the sinus optimized machine be at home then? When you optimize it for max torque it will no longer be a quasi sinus so what you going to do about those HELPFUL BLDC harmonics guru?
This is the hard part. lets see if i can get something REMOTE about it.....:ghost:
I've commissioned many FOC VFD power systems that utilize current flux control algorithms professionally on an industrial scale for Daimler so lets talk about it.
You know and I know that you and Ralph are in this room right now so kill the forum bs! and join the class discussion direct!!!
I don't have time for the twinkie ass ****. All your friends already know you are here, so Be MEN!
You talking about "strange American" but who does that? Look at yourselves... You are extremely weird since you both have already posted in here....
Who takes you seriously anyway then?
YT
HubertComment
Right do the values come with a voltage and RPM??? :face_with_monocle:
and so then after that this is still just the claimed electrical consumption now you need a mechanical out to determine a real eta. Should be interesting because Lehner 41 reports 93%..
So turn the props. and drop the real data
Happy amps Christian.. Hans 2260 2 pole is a tru sinus flows over 1000 amperes at higher efficiency and speed and has not a single tooth with wrapped copper around it boo boo..
TTYL
HubertComment
Long ago Ralph I gave your patterns for a rhombic winding. You can glue that rhombic overlapped lapped winding to a iron cylinder and build a slot less outrunner. In fact you could print non magnetic teeth that go around the iron ring to arrange the coils. Those patterns and post may be on rc groups from a ways back. The ring could be an amorphous iron spiral strip core. You dont need iron teeth at allComment
The windings you truly could cut from copper foil tape then insulate each phase layer with epoxy before applying the next overlapping phase.. That would be extremely compact if you take your time and plan it out. with your scalpel. You could lay it on a mylar or kaptan tube. Like for a speakers voice coil..If you insert a flux ring after that it will generate real torque. You print a to scale template on a flat piece of paper and wrap it around the tube.Comment
You can see it is a inner an outer rotor toroidal design.
Who you think is stirring the pot remotely there???Huh?
