Originally posted by TMoyer
View Post
Here is a new one for you guys. I use a vinyl clear coat from Orielly auto parts in a rattle can. It sprays on gloss but with a fine steel wool it dulls down nice. It's very flexible and does a great job against UV damage. Been using it for about 7 years now with no issues. On my shiny metal P51 I didn't even dull it down..has looked great for a long , long, time now.
Howabout Posting a picture of the can !! I'd like to try it.Originally posted by prestonowtm View PostHere is a new one for you guys. I use a vinyl clear coat from Orielly auto parts in a rattle can. It sprays on gloss but with a fine steel wool it dulls down nice. It's very flexible and does a great job against UV damage. Been using it for about 7 years now with no issues. On my shiny metal P51 I didn't even dull it down..has looked great for a long , long, time now.
I started a post in Airplane Tips and Tricks requesting information from anyone using the Min Wax PolyAcrylic clear (flat/satin/gloss-take your pick) and it seems those using that (it's a brush on) have had excellent results. A friend just re-painted in Tomcat Jolly Rogers with new graphics from Callie and applied the satin and it not only looks outstanding, but has given the foam, paint and Callie's graphics a much more durable covering. The PolyAcrylic gives even a tougher coating than urethane. I've gotten myself a gallon and if it works out, I plan on covering at least 10 of my planes, including both my F-4's, 2-B-24's, a Spitfire and my new 1600mm Corsair. Let you know how it works. :Thinking:Originally posted by TMoyer View PostNo problems with the WBPU yellowing? I remember from many moons ago, Pactra had Formula U for the nitro stuff. It was a urethane. I used the clear a few times and after a while in the sun it yellowed like crazy. Really looked bad after a while.Hugh "Wildman" Wiedman
The V tail option is for a plane that uses a "Ruddervator" which combines the elevator and rudder. Since the F4 uses dedicated flight surfaces for each it probably wouldn't work very well.Originally posted by prestonowtm View PostOn a different note I use a Spektrum transmitter..setting up another plane today I noticed the V tail setting. Anyone tried using this on the F4?1 Photo
Hey Y'all, Small steps. Stripped the OEM acrylic paint and repainted the canopy with Dark Sea Gray first to the match interior color, then FS36440 outside. The canopy support structure was too wide, so I narrowed the frame at the Pilot & WSO/RIO Stations with the repaint opening the glass area at the center. Looks better, I think, and the frames are closer to scale which eliminated the squished and pulled looking sections. Stripped the OEM acrylic by soaking paper towels with 91% ISP (suppose 70% would work too) then wrapping that with plastic wrap to slow the evaporation. This dissolved the OEM paint in an hour or so. Clean up with more ISP and 'boom' no paint. Best, LB
Nice work!Originally posted by Elbee View PostHey Y'all, Small steps. Stripped the OEM acrylic paint and repainted the canopy with Dark Sea Gray first to the match interior color, then FS36440 outside. The canopy support structure was too wide, so I narrowed the frame at the Pilot & WSO/RIO Stations with the repaint opening the glass area at the center. Looks better, I think, and the frames are closer to scale which eliminated the squished and pulled looking sections. Stripped the OEM acrylic by soaking paper towels with 91% ISP (suppose 70% would work too) then wrapping that with plastic wrap to slow the evaporation. This dissolved the OEM paint in an hour or so. Clean up with more ISP and 'boom' no paint. Best, LB
And ISP is = Isopropyl Alcohol ?
How did you install the nerf whistles? I have some but didn't really want to cut holes in the foam and they are all too long to install without cutting the bottom off of them.Originally posted by Greyhound61 View PostFinally, my F-4 is ready to fly. Maiden planned April/May. Stock 6s with JP-brakes, 2 NERF whistles and gyro. Looking forward to fly this beast :-)
Here is a close up look at the drogue chute on Ivan's F-4 Phantom.
360 degree video featuring a close look at Ivan's F-4 Phantom drogue chute assembly. Please pan and zoom for your perfect views. You can pause the video any ...There are hundreds of RC aviation videos viewable here; WBRC
