  • Lcacing
    • Dec 2017
    • 155
    Originally posted by curlyculp
    The rudders have a reversed servo too, yes?
    Rudders don’t need a reverse servo, both are standard rotation on a Y.
      • 5401
      I was talking about the stock MCBe. But as I said I wasn't sure if it turned off steering. I'm still not sure it's supposed to. But in my F-18 (and F-22) I bypassed the MCBe and have each rudder and the steering going to the receiver directly, each to their own slot and everything is done via programming.
      Sounds like you have a problem. Is each rudder and the steering going to separate slots on the MCBe?
      Originally posted by DCORSAIR
      Are you talking about the stock blue box that the F-18 comes with? If so, it does turn off the steering when retracted, that is where I was having my problems and almost crashed mine on the maiden, everytime the gear retracted and the blue box cut off the steering, my rudders would go left about 5mm on their own, then when I dropped the gear and the box would turn on the steering, my rudders went back to normal, I bypassed the BB and 46 flights later all is good. So I think alot of these problems are related to this delay in the gear myself, wonder if the power being cut off to the steering servo is cutting off power else where, just wondering is all, and I did see where they might be doing away with the delay on the gear.
      • Imladris18
        • 21
        Originally posted by Quax
        Thanks for confirming that.
        I am curious on how this jet performs and cannot wait to get it in the air. I am thinking about scale features like rudder toe-in for pitch up when flaps extended or even toe-out as speed brakes (however, as far as I know only used on the Super Hornet).
        I'm not aware of any rudder flare on the Legacy, but rudder flare on the Super Hornet is only used when at a very high AoA and a large pitch down movement is commanded (I believe it's referred to as Turbo Nose Down). Both versions use toe-in for braking and pitch authority otherwise, so it would be most practical and realistic to only worry about toe-in programming.
        • Quax
          • Jun 2019
          • 77
          • Bergisch Gladbach, Germany
          Yep, that is according to my information - only on Super Hornets together with ailerons up: https://www.quora.com/Why-do-twin-ta...-for-stability
          However, I was thinking about trying this on the F/A-18C model as well as it looks very fast and loosing speed could be an issue.
            • 8225
            Some great shots from Seafair weekend where the Blue Angels performed their annual airshow over Seattle...
            KOMO 4 TV provides news, sports, weather and local event coverage in the Seattle, Washington area including Bellevue, Redmond, Renton, Kent, Tacoma, Bremerton, SeaTac, Auburn, Mercer Island, Bothell, Shoreline, Lynnwood, Mill Creek and Everett.
            • RCGuy83
              • Jan 2019
              • 126
              Don't know if you know this but the factory Freewing 17g Servos make 60oz/in *4.8 volts. While the Hitechs 85mg only make 40oz/in.
              The 17G servo data on our website is WRONG on some of the various wire lengths. The 17G all metal gear servos make 35oz/in at 4.8V NOT 60oz/in. it makes 42oz/in at 6V but I would not use 6V so as not to upset the Blue Box. The Hitec HS-85MG's make 42oz/in at 4.8V and feel great in the elevators!
              Click image for larger version  Name:	17G.JPG Views:	0 Size:	50.7 KB ID:	209054
              • thisguy65
                • 509
                Guess the first servo I click on had wrong info then. Lol. I typically buy servos with longest wire as I can make them shorter if/when need be
                Planes
                • DCORSAIR
                  • 1918
                  • Selma, Ca.
                  Yes, the steering is supposed to stop working when retracted, same on the L-39, and yes the steering servo and rudders go into seperate slots on the MCB board, I only can have 7 channels with my radio so I can't seperate my rudders like you did straight to the rx but I bypassed the board with a Y harness and put the rudders and steering together, no problems since, so my issue seems kind of strange but I proved it was the MCB board, my board actually worked fine on everything else, only when my nose gear retracted and cut off power to the steering servo, then only the rudders would go to the left, so my box had some sort of glitch.
                  • fredmdbud
                    • 451
                    Just curious, but why did you not bypass the airlerons and flaps too? My flaps went split once... briefly... and have heard other flap stories.
                    Didn’t want to add another Y cable to the rats nest, plus the servos checked out with no jitters or glitches. At the first sign, then I’ll bypass them and retest to isolate if it’s the servos themselves.
                    • curlyculp
                      • Jun 2018
                      • 133
                      Oh yeah, because they're mounted on different sides of their respective rudders. Duh. ;)
                        • fredmdbud
                          • 451
                          Even if they were mounted on the same sides, it’s the orientation that counts - either both clockwise or both counter-clockwise, the rudders will deflect the same direction.
                          • curlyculp
                            • Jun 2018
                            • 133
                            Now you're making my head hurt. (but I see you're right)
                            • Carlbrainiac
                              • May 2019
                              • 242
                              EU warehouse finally saying in stock of the base grey pnp but I haven't got my shipping notification yet...
                              • fredmdbud
                                • 451
                                Patience - you're in the queue ...
                                • Bobaroo
                                  If it Ain't Right on the Ground...
                                  • Dec 2017
                                  • 327
                                  • Newburgh, IN
                                  • Carlbrainiac
                                    • May 2019
                                    • 242
                                    Patience,,, I've been waiting since f**king 14th of May! Lol
                                    • fredmdbud
                                      • 451
                                      You can wait just a little longer, or ask for a refund. If you have a third option, lay it on us …
                                      • Carlbrainiac
                                        • May 2019
                                        • 242
                                        3rd option is keep pestering motion till they listen and send mine out lol. It's only because this is my 2nd of 2 weeks off work. I'm back to work next week. Would love for it to come this week
                                        • Carlbrainiac
                                          • May 2019
                                          • 242
                                          It's a mistake on the webpage. They aren't being shipped till Monday 12th ☹
