  • viper1gj
    • Feb 2020
    • 81
    Originally posted by F2coffee
    Well I am every disappointed with the mig-29 my granddaughter fly twice and the 3 time the Elevator linkage bend so is there any linkage that will be strong
    I replaced the stock linkage with 4-40 threaded rod with carbon tube sleeve. It won't bend.
      • 5387
      Even the original thin wire in carbon wouldn’t bend, I’m wondering if he’s talking the horn or what…
      • Airguardian
        Post Stall Svengali
        • Aug 2020
        • 1664
        • Catalonia
        • Airguardian
          Post Stall Svengali
          • Aug 2020
          • 1664
          • Catalonia
          The more I fly, the more fun it gets!
          • GliderGuy
            • 1408
            So fun to watch a pro driving a MiG!
            I forget….gyro or not?
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1664
              • Catalonia
              Thanks, GG!
              No gyro, yet... But I'll be soon adding an ET Vector FC to the jet to have a proper OSD for FPV, and then I'll use the gyro in it.
              I may also add another standalone gyro for the nozzles, while at it... we'll see.
              So far, all my flights with the MiG have been unstabilized. :)
              As a matter of fact, you can often see the MiG drifting ass / dipping wings unintentionally in some of the maneuvers I do...
              Ofc, it's easier for me to tell when it's doing something I didn't actually command, haha!
              • radfordc
                • 375
                • Lansing, KS
                Well I am every disappointed with the mig-29 my granddaughter fly ti twice and the 3 time the Elevator linkage bend so is there any linkage that will be strong
                You recently complained of a sticking elevator and now bent linkage. You have been remarkably non-verbose in describing your problem!
                • Red B
                  • Jun 2023
                  • 4
                  Got a question about the elevator servos. Mine seem to be ratchety if that's a word. They are not smooth at all.
                  Any thoughts?
                  Thanks Red.
                  • nuts-n-volts
                    Duke City Electric Flyers
                    • 251
                    • Albuquerque, New Mexico
                    Replace them with something better. If I see something wrong with equipment, I don't wait or keep flying it that way. I'm very proactive. I figure it out and fix it. I used Promodeler 160s on my elevators. In fact I changed all servos over to HV and I run the Rx and all servos on a 2sLiPo. No, you don't have to go this far, but in my opinion, this plane needed it.
                    Fly low, fly fast, turn left
                    • Red B
                      • Jun 2023
                      • 4
                      Any thoughts?
                      Thanks Red.
                      Another thing. The servos run smoothly when hooked directly to a servo tester. Could this be a blue box issue?
                      • Red B
                        • Jun 2023
                        • 4
                        Did you by-pass the blue box? Thanks for the reply.
                        Red
                          • 5387
                          I'm not going to second guess the ratcheting, could be transmitter, receiver, MCBe, extensions or servos..
                          He has to bypass the MCBe for things running HV and keep the MCBe for at least retracts, gear doors and lights.
                          • nuts-n-volts
                            • 251
                            Yes, bypassed. Evan is right on. The blue box only gets power from the bec to run retracts and lights as these are limited to 5.1V ...on mine anyway.
                            • TGoelzer
                              • Sep 2021
                              • 28
                              • Fort Mill, South Carolina
                              Anyone else notice that the current inventory on the Mig 29 now has the New 80mm edf fan?
                                • 5387
                                Yeah, and the Avanti, Mirage, F5… looks like all will switch to it.
                                • TGoelzer
                                  • Sep 2021
                                  • 28
                                  I might buy 2 units and install them in my Mig 29 and see if that makes a big difference
                                    • 5387
                                    It will. Swapping out the EDF in my Gripen was a huge boost but it should be, the older units in the MiG make 101A and 2291W. The new EDF in my Gripen makes 127 and 2857, a 25% increase.
                                    • nuts-n-volts
                                      • 251
                                      Evan, did you notice a flight time decrease because of more power used? Amount?
                                        • 5387
                                        Yes, I reduced my timer 10 seconds but may reduce it more. I have this in my Gripen which I seldom fly full throttle, just occasionally to see that it does, in fact, have good vertical. Most my flight is flips and flops, 3D type stuff.
                                        • nuts-n-volts
                                          • 251
                                          Right on. Thanks!
