Official Freewing 90mm Eurofighter Typhoon EDF Jet Thread
    • 5385
    I have the 6S and did some weight and balance work to see what I would have to do for my JF/HET system to go into it using batteries that are a 6+2, with the 6S being 575-645g and the 2S being 250g.
    When I built mine I put two 21g slugs in the stinger to have a good balance with the 6S, balance at 25-30mm behind the marks, 25 without stores and 30 with stores.
    To balance the 6+2 and 8S fan would take serious weight in the tail (I forget the number I came up with but more than I wanted to consider). I did calculate that if I put the 2S under the speed brake it wouldn't take any additional weight, or a very minor amount. Adding an AB is very minor as little as they weigh and as far forward as the fan is.
    Admirals are usually heavy and to consider 6000's??? Why not go with around 4500-5000?
    • TonyTaff
      • Oct 2017
      • 39
ID:	374568Click image for larger version
ID:	374569Click image for larger version
      Decked it out in RAF Demo team livery Callie Graphics did a good job. Still waiting on a couple of RAF roundels to cover Spanish ones See the battery bay No wiggle room
      • TonyTaff
        • Oct 2017
        • 39
        In answer to Evan D this is what Motion RC had listed as recommended I guess I should not confuse sell with install....
          • 5385
          Wow, 624g ea for 1250g of battery is crazy. You would probably have to add close to a pound of weight in the back to get a decent flight balance (I don't consider the marks a good flight balance).
          Edit- ​1250g compared to the 645g batteries I'm using and I have 42g of weight in the stinger (further back from the CG as the battery is forward of the CG) add a ounce or two where the fan is and quick math means you'd need about a pound and a half at the rudder area to balance where I'm flying. I don't think that would be practical. If you used their recommended 5000 6 +2 that would be 645 + 285 or 930g. Unless you put the 2S under the airbrake you would need a lot of tail weight with this combo too.
          I guess their recommendation is based on what they sell. The manual they post on Motion is the 6S one with 6S battery recommendations (760g 6S battery shown in the picture in the manual).
          • kallend
            • 1859
            I do have a freewing afterburner installed but lets not get into its functionality
            The lamp is good. The controller can be fixed.
            • kallend
              • 1859
              Are you going with the Black Jack scheme?
              • Drifty
                Old A/C mechanic
                • 55
                • Temperance MI
                Good scheme Tony!
                • Czonio
                  Chris
                  • 17
                  https://www.ebay.com/itm/32558998791...mis&media=COPY
                  • kallend
                    • 1859
                    • Radar-Guy
                      AirBorn Jetworkx
                      • 364
                        • 5385
                        Seems my changes have fixed the roll issue.
                        • Apriliamgt
                          • Oct 2017
                          • 73
                          I like the scheme / livery , but something just not sitting right with this one , I think it would definitely suit a “black” fuzz and wings . I’m kinda glad in some way I didn’t order these graphics frpm
                          callie now . As I had no intention of painting it black
                            • 5385
                            John, did you get to fly yours?
                            • kallend
                              • 1859
                              This John didn't.. We got strong winds and thunderstorms.
                              Maybe Tuesday. If not, mid May as I'm off to Australia and NZ for 6 weeks, leaving Friday.
                              • kallend
                                • 1859
                                Finally got it in the air today. Wow, does it ever land nicely. That's it for me until mid May.
                                  • 5385
                                  Congrats!
                                  • TonyTaff
                                    • Oct 2017
                                    • 39
                                    Yes I understand I did not want to paint it like the black jack scheme either... I think its a good compromise and good visibility better than all grey.
                                    • TonyTaff
                                      • Oct 2017
                                      • 39
                                      • Tomling31
                                        • Nov 2021
                                        • 22
                                        Hi everyone, does anyone know when the typhoon will be available again for delivery into the UK?
                                        thanks Tom.
                                        • viper1gj
                                          • Feb 2020
                                          • 81
                                          I went to Home Depot today and got this paint mixed up from a scan off the top of one of the canards. Got home and did the finger "dab test" on the wing root area and it looked like a perfect match. Certainly good enough to cover my mods on the bottom of the fuse and to fix any hanger rash in the future.
