  • tirolguy
    • Jan 2019
    • 7
    Originally posted by Waconut
    Rob,
    Some guys use a rounded point to create a divet in the foam. I used a .093 dia aluminum tube, I sanded the end smooth and pressed and twisted it into the foam surface. You have to be careful not to penetrate into the foam. The .093 is just what I had on hand. If I were to do it again I would use .063 dia. Tubing.
    Here is a pic of how mine turned out.
    Hope this helps!!
    Anthony
    Thanks a lot for the Information, i will do it exactly like you told.
    Regards Rob
    • Waconut
      • Feb 2020
      • 310
      • Cincinnati, Ohio
      Regards Rob
      Rob,
      This was my first EDF and foam plane. I used to be big into giant scale. Anyhow I have a FW F-86 due to arrive tomorrow. I will be giving the plane a lot of detail and a new paint job. I will sealing the foam with Polycrylic then using high fill primer to smooth out the surface of the plane. I am then going to add rivet details by using the tubing inserted into a low wattage soldering iron. Just burning into the primer and Polycrylic. Should make for better flush rivets. I will be posting in the F-86 thread if your interested.
      Later!!
      Anthony
      • Dustman
        • 81
        Took some time off from my F-18 to install my DD cockpit in. I have a couple other pic's I will post later. The pilot is from JHH and and it's the perfect size. The trench in the sides of the A-10 is 6mm square for carbon rods to add strength to the model in case of a hard landing. I copied the setup of RCSkunkWorksADP in the following videos; https://www.youtube.com/watch?v=3fB35t7fRWc , https://www.youtube.com/watch?v=79DnmqS-i0g ; I have also installed the mod main landing gear that FreeWing offers. If it's possible to still buy one of DD's kits you won't go wrong by getting one.
          • 4875
          Dustman, Great work, DM. and thank you sharing those vids. Best, LB
          • Warthog
            • Feb 2020
            • 119
            • Crockett, TX.
            What I want to know is, what kind of paint has everyone been using on these pilots? I have tried Testers spray paint and it seemed to be alright, until I TOUCHED it with a fingernail, and it came right off! Then I used the water base AV Air model paint and it beads up like the surface is waxed! What now??
              • 4875
              WH, if you're writing about the JHH Pilots, I hear ya. I've washed those in soapy water and even solvent and whatever it is, acrylics don't stick well and enamels rub off. I now spray a black automotive primer from Krylon (Home Depot) and then use acrylic and/or enamel paints. Best, LB
                Elbee is right, for resins like these, use proper primer after a thorough cleaning (soapy water and toothbrush). I rinse and scrub the figure in water water afterward to ensure all the mold release is completely removed from every nook and cranny. Enamel primers are best.
                • Warthog
                  • Feb 2020
                  • 119
                  • Crockett, TX.
                  Thank you both! I thought I was losing it. I even tried wiping it down with lacquer thinner, after soap and water didn't work. I tried wiping with acrylic airbrush thinner. No go.
                  • Glazier808
                    • Feb 2020
                    • 25
ID:	245525Click image for larger version
ID:	245524Click image for larger version
ID:	245523Click image for larger version
ID:	245522Click image for larger version
ID:	245521Click image for larger version
ID:	245520 Thank you very much to gravity-tester! Was able to change up my ords little bit🤙🏽
                    • Warthog
                      • Feb 2020
                      • 119
                      • Crockett, TX.
                      I cleaned up the bad paint, and found some plastic primer. It went great!! Almost done with detail painting. Thanks to you both for your help. John
                      • Dustman
                        • 81
                        WH where did you get the shinny visor from? I want to redo the one on my pilot.
                        • gravity tester
                          Hobby Squawk Pilot
                          • 70
                          • Westfield, IN
                          Glad you could put them to good use, Casey. That is one mean looking Hog! Now you just need a few rounds of 30mm combat mix and you're ready for battle.
                            • 4875
                            DM, I used Model Master Gloss Black and a water color brush that holds a lot of paint. I started in the center of the visor and pulled the paint to the edges doing 1/2 at a time and always starting from the center. The brush never touches the visor, only the paint. It's almost like a drip that you manipulate to the edges of one side and then redip and do the other side. Gotta work quickly but not fast, if you know what I mean. I then laid the pilot on his back, visor facing up, and walked away leaving over night to dry. I have done all the visors on my pilots that way since. Hope this explains my process. Best, LB
                            • walkerm45
                              • Aug 2014
                              • 74
                              • Tucson, Arizona, USA
                              Can anyone recall when the attached pic of a Canopy operating mechanism was posted? Additionally, can this item be purchased? I appreciate any info on this interesting subject Click image for larger version
ID:	245730Click image for larger version
ID:	245731 . Bronco Mike
                                • 8835
                                I can't remember exactly when, where and by whom that canopy opening mechanism was posted, but I had the LX A-10 that had this feature in the stock plane. Banana hobby sells that A-10 under their brand "BlitzRCWorks". Here is a picture of that canopy open:
                                Banana also sells the mechanism: https://www.bananahobby.com/canopy-o...1576-prd1.html
                                You may be able to adapt it to this A-10. The other option is to invent your own based on what you've seen.
                                  • 4875
                                  WM, the only person I recall that had a video of an operating canopy was RCjetdude and Pogo. I believe those were both scratch-built. It would be very early in this thread say Fall of 2017. Hope this helps. Best, LB
                                  • walkerm45
                                    • Aug 2014
                                    • 74
                                    The operating canopy looks professionally built. Very simple unit, and easily adaptable. Looks like a job for DD.
                                    • Pogo
                                      • 452
                                      • Waterford, Ontario, Canada
                                      I think that mechanism shown is from the LX A-10 and I considered using it but decided adapting it would be as much work as making a more scale scratch built version. I scaled up parts from a Tamiya plastic model I have and fortunately it pretty much worked out the first time. Getting the geometry right with things like this is always challenging and of course "the devil is in the details". I wish I had .stl files to share for the parts but everything is made from wood, plastic etc. so...
                                      Here's the video first posted in 2017 showing the canopy gong up and down, up and down, up and......
                                      Tom
                                      https://www.youtube.com/watch?v=sb9Z...ature=youtu.be
                                      • MikeT
                                        Here......Hold my beer.
                                        • 1060
                                        Tom
                                        The LX used a jack screw and was junk. Been there done that.
                                        Mike.
                                          • 8835
                                          Mike.
                                          Me, too. After looking at it out of the package, I labeled it and tossed it into my parts box, never to be seen again (until I threw out the box). It was, however, the only "manufactured" mechanism of its sort at the time.
