There are several offerings on Amazon for the RF chokes. Search Amazon for clip-on ferrite chokes. Get a variety pack...you'll be glad you did (small, medium and large).
It was back in 2018 when I was flying the A-10. Was using the Venom Fly 30C 5000 mAh batteries then.
Flight times are so "individual to flying style" that it's hard to compare. But, my A-10 had the outrunner EDFs. As mentioned by Hugh above, a 5 min flight was typical for the mixed throttle flying (50% mostly then to the occasional 100% aerobatic push). As I recall, the batteries would get pretty warm during a flight. I did not have a battery meter back then, so I cannot comment on post-flight battery voltages. However, inrunner EDFs are typically more efficient, so 3 min "seems" short for inrunners. See below...
I get 4 min on the MiG-29 running 75% mostly to 100% for aerobatic pushes for 2.5 min and 50% for another 1.5 min and land with about 3.7 volts and about 3800 mAh consumed by the 80 mm inrunners of the MiG. Could easily go longer if I flew more conservative, but (1) I like to leave about 30% to 40% in reserve....the LiPos last longer and (2) take less time to charge if I use less out of them per flight. Note: The MiG is using the Admiral Pro 6000 50C batteries. So, not a true apples-to-apples comparison for Gringotuerto.
As another point of comparison for the 6000 mAh, the F-4, 90mm outrunner, gets me 3.5 min total with 2 min of 75% mostly to 100% for aerobatic pushes and 1.5min with 50% throttle with about 3.7 volts and about 3900 mAh to 4000 mAh consumed.
Just a thought...have your verified your timing settings for the ESCs? Are you timed more aggressively?
And it definitely is not pitchy and tail heavy. I am flying with an AR637T with gyro gains in the 60% range, so that may help as well.
