  • Pete Lane
    Turbine lover
    • 290
    • Los Gatos Cally
    • Callie Graphics
      • 56
      • Magdalena, NM
      Pete Lane: I'm afraid we don't have the equipment to create full wraps.... so sorry we couldn't help with that!
        Originally posted by T-CAT
        For anyone stacking batteries (I believe RCdude is and maybe some others as well), did you decide to use a completely new battery strap of larger length to accommodate the increased length needed, or did you end up combining both stock battery straps to make one (as they catch at each metal piece)?
        The stock battery straps are quite long and should be sufficient to secure around just about any size lipo this thing could take.
          • 2137
          • On planet earth....right
          Each one is too short though to use just one strap to secure both batteries stacked one on top of the other. They would have to be joined together. I'm not sure I trust them once joined though, as stacking one on top of the other adds some serious heft, and the velcro isn't too strong. It's plenty strong and secure for the traditional single battery use, but double stacked is questionable. :)
            Ah, yes, stacked batteries will have issues. When I have this problem, I pull out my roll of double-sided velcro and make my own straps. I had to do this on the Tigercat as I am using Turnigy Graphene 4S 4000 packs in it, and the stock straps were too short. And this reminds me, I need to do this to my Mig-21 as that strap is too short for the larger pack I'm using.
            https://www.grainger.com/product/5JL...170616161807:s
              • 8205
              Going to try to maiden this evening as long as the weather holds. Thinking about where to put my Mobius for a nice POV. I don't want to have to add counter weight so I may stick with a typical around the CG POV...Ideas?
                • 2137
                Awesome, thanks. I was thinking of doing the same exact thing as I had a roll of that velcro, but I must have purchased it long ago and not have realized that it is very weak velcro. Time to head to the hardware store in hopes of finding long velcro that's strong. Each LiPo I have weigh about 910g, and stacked on top of one another has me a bit worried to be honest. I may add a few more screws in the wooden tray as well for added assurance.
                  The actual Velcro brand that I linked to above is plenty strong to use as a securing strap for batteries. I have used it on several planes.
                  • Mike_Then
                    I hate waiting for parts
                    • 179
                    • Leander, TX
                    It.may not affect the CG much at all but always good to check. At any rate, good luck!! Tomorrow is my maiden in between rain showers
                      • 2137
                      Thanks Pat. I'll see if I can find the exact same kind.
                      • Lon
                        • Jul 2014
                        • 1201
                        • Miles, Iowa
                        Hey TomPatton, thanks for pointing that out.Does anybody have the C.G.established and maidened the plane with two of the NEW admiral 5000s. Aros had great info on that but he is using the old style batteries. The new ones are a full inch longer! Thanks, Brad
                        Brad,
                        Here's where I'm happy with CG and the new Admiral 5000s
                        Lon
                        • downwindleg
                          • 1279
                          • Friday Harbor, Washington
                          What about mounting it on one of the rocket rails?
                            • 8205
                            Good idea, I should look into that too! Here's a quick video I put together...Suggestions welcome! (I called and left a message for ya Brad...ONE day! Whoooo!)
                            • dahawk
                              Augermeister
                              • Jun 2013
                              • 1006
                              • Keller,Texas
                              I'm hopeful for a Sunday( Fathers Day ) maiden. While waiting for the wind to die down, I put together the 70mm F16 v2 w/ AB and strut upgrade. So, two maidens !
                                • 8205
                                Nice. Outside of the Avanti, that 70mm V2 F-16 is my favorite jet to fly at the moment. Total blast.
                                • downwindleg
                                  • 1279
                                  Originally posted by DrDeath
                                  Just bought them in late May. They are long and skinny compared to the old fat ones
                                  Thanks DrDeath, to be clear the front end of the lower battery is at the second long oval back from the stepdown?
                                  • downwindleg
                                    • 1279
                                    Hope you can get the maiden in today and it goes well. Maybe it can fit on your roof rack to Friday Harbor if it does.:) Is that your wingman Chris in the video? Brad
                                      • 8205
                                      Thanks! Man if I could, I would! No that's my neighbor...
                                      • DrDeath
                                        • 91
                                        You can see the green line on the starboard side. That's where I place the end of the battery. Sometimes it may go a little toward the step down, but pretty close to the green line. FLIES GREAT!!!
                                        Click image for larger version  Name:	battery placement.JPG Views:	1 Size:	113.6 KB ID:	81638
                                        • downwindleg
                                          • 1279
                                          Originally posted by Lon
                                          Brad,
                                          Thanks Lon, can you give me a measurement? It's difficult to tell positions from that angle. Brad
