I have been flying the Avante S for about two years now. One of the best airplanes I’ve ever flown thank you motion RC for providing this airplane here is a video of what I’ve been doing with it. https://youtu.be/Oa025UCsf9U
Originally posted by Kiwi41000 View PostI have been flying the Avante S for about two years now. One of the best airplanes I’ve ever flown thank you motion RC for providing this airplane here is a video of what I’ve been doing with it. https://youtu.be/Oa025UCsf9UHugh "Wildman" Wiedman
Originally posted by Kiwi41000 View PostHer driveway was too short I had to land somewhere else. Kiwi4Hugh "Wildman" Wiedman
Originally posted by Hugh Wiedman View Post
Probably for the best as I've heard that "Grandma" may have been replaced by a politician with a long tail and sharp teeth!
Hello everyone
Had anyone had luck removing a flap servo without wrecking the surrounding foam. Or any tips? One of my flap servos center point is noticeably different from the other, I’d like to keep using the board rather than plus in one separate servo on the Rx, so I’v currently put a mix in. But I’d like to get it out and re centre the horn.
Originally posted by Evan D View PostI normally leave the servo in and push a thin Phillips screwdriver through the foam to undo the servo screw.
If I really need to remove a servo because it has failed, I run a hobby knife around the edges (avoiding the leads) and I hook a paint can opener under the body of the servo and pull it out. The adhesive is kind of gummy and will give fairly easily.
I would of thought it’s 2 or three cogs out. Factory worker must of been tired that day. We all make mistake. That’s the issue mate one flap is a few MM lower than the other, with an aileron mix it’s not shocking but it’s not right. Thank for the pointers I will have a look at points mentioned. Good idea about the screwdriver. Another advantage of foam I suppose 😂 Many thanks.
Originally posted by Nathan99 View PostI have recently ordered a Avanti, I would like to paint the canopy blue like the one in the product photos. What colour of blue is it? And can I paint the tinted canopy without much difference in the shade of the blue or should I get the clear canopy and paint that?
Originally posted by Nathan99 View PostI have never painted a canopy before but I have heard from a few people that are into cars paint their car bodyshells that way, any good way of testing the shade of the blue or how many coats before I actually paint the canopy?
You don’t necessarily have to remove the servo you can cut a deep V that allows you to have access to the screw and then you glue the triangle back in I’ve had to do that on my Avanti
thanks mate I’v done it and glued it back in nicely, you’d almost never know. 👍👍
thanks Doug
