now what? Some of us aren’t 3D printer knowledgeable. Thanks for your help with the file though. Can I just send that file to somebody online, pay them some $$ and the part shows up in my mailbox a week later?Originally posted by Hemidoo View Post
Yes, or if you have a buddy who has a printer, buy him a drink !
Sent an email to Chris (rc geek)
for print help. Dirty Dee also is an expert 3D printer
- Likes 2
Hi thanks for your help. I should have mentioned I’m not a newbie with flaps as I have several including fms tigercat. My current problem is when I first powered up the Avanti all the servos moved to centre including the flap servos. But as of last night I can’t seem to get them to move now. Not had time tonight to look, but obviously power is there as they moved on power up, maybe my programming is at fault. I’m using Spektrum iX12Originally posted by xviper View PostSetting up flaps is not that hard but it does need a sequence of events to make them work. Did you go into the servo sub-trim menu for flaps to try and "zero" them out as best you can? Then, did you go into the flap system page and assign the proper switch and deployment speed? Then start with the flap position "0" and dial that in to set the flaps as neutral as possible? Then moving to position "1", dial in whatever it takes to get you a desirable take off flap? Then go to position "2" and dial in whatever it takes for landing flaps? If your elevator is moving, that means you've dialed in some compensation but at this point, maybe that's not a good idea till you find out exactly how much you need. Start with that at zero. A slow flap deployment should negate any need for elevator compensation.
I have 2 landing gear braces for this plane if interested (40.00/ea), they are yellow and 3D printed from; Here is the .STL for the Nose gear brace/support for Freewing AvantiS :
https://www.thingiverse.com/thing:2553111
I'll take one. Can we do Paypal?Originally posted by Dave_oh View PostI have 2 landing gear braces for this plane if interested (40.00/ea), they are yellow and 3D printed from; Here is the .STL for the Nose gear brace/support for Freewing AvantiS :
Thx T-CAT.Originally posted by T-CAT View Post
Welcome! I have used the 80mm FW inrunner power systems many times with a Hobbywing 100A (if you have any other Freewing 100A ESC’s from other planes lying around, it works great and is the same). An 80A just doesn’t provide enough headroom/safety-cushion for the current draw on the system. It’s better to be safe the sorry. The 100A FlyFun Hobbywings can be found relatively inexpensive and tend to be very reliable. The Gecko 125A/155A will likely work as well, but depends on the firmware sometimes as it can take some configuring to make some systems run smooth. Usually with the 80mm Freewing inrunner power system, low timing works fine, but if it doesn’t run smooth on low timing then medium usually cures it. If you purchase the Freewing/Hobbywing ESC and need to change the settings easily, we can point you in the correct direction for a program card.
Dahawk:Originally posted by dahawk View PostYes, or if you have a buddy who has a printer, buy him a drink !
https://www.thingiverse.com/thing:2873634
Thank you for sharing the file on the Avanti Nose Brace. I'm not a 3D printer guy (yet....), so I clicked your link and ordered three RED braces from Print A Thing (I ordered two for spares - hopefully I won't need them). I got in on the pre-order for the RED Avanti, so I hope to see the jet later this month - can't wait!! Anyway, Print A Thing charged me $1.89 each, plus a $4.50 printer set up fee, and a $4.50 shipping fee - total for all three pieces was $14.67 (plus $1.00 for a tip as recommended on the site). I ordered the braces on Friday (8/31) and got them today (9/4). I can't wait to receive my jet and get the brace installed. The picture shows the top and bottom view of the brace, and of course I will drill the holes for screw access. My sincere thanks for sharing the file for us non-3D printer guys. If we ever meet, the drink is on me!
Regards,
Jim
Mine were so bad I decided to make new ones. Went ahead and flew it without them. The airplane flies great so I never got around to making them. I have flown one with and mine without. I can't tell the difference.Originally posted by Marksj100 View PostBeautiful quality kit is let down by poor quality wing fences mine are distorted so I’m looking at possible materials to make new ones from. Anyone had or done the same ?
Rick
My Avanti had an argument with a sagebrush. the result was the leading edge of the wing got dented in. At first I was just going to get another set of wings, but then I considered it a challenge to repair her.
First step was to lay a soaking wet towel over the damage and heat the area with a hair dryer
this is after the steaming:
Then I started working it out and used Foam-Tac in the cracks and Foam Filler on the leading edge to regain some of the strength.
Afterwards, the whole surface was covered in Foam Filler and sanded several times
To the point where she looked pretty good, then some paint matching and a lot of Minwax Spar Varathene that I allowed to roll down into the dimples that were not quite gone yet. Hand painted the graphics, not the greatest job and the grey isn't quite right, but good enough until Winter/repair season kicks in.
She's ready for the air (hopefully) again!
- Likes 4
I'm not familiar with foam filler at all.Originally posted by Grossman56 View PostMy Avanti had an argument with a sagebrush. the result was the leading edge of the wing got dented in. At first I was just going to get another set of wings, but then I considered it a challenge to repair her.
What is is like, what is some brand names, and where can you get it?
