  • 73 flights so far.
    All going strong, only 1 dead flap servo.
    • Comment
      • Ive had great fun with my Avanti over the past two years and have now purchased the Wemotec 8s set up for it. Those hwo have converted to 8s already, what size battery packs have you managed to squeeze in?
        • I used Hobby Star 5200 6S + 2S when I had mine 8S. Power Hobby 5200 6S and Coddar 5200 2S are my current go to for 8S. I also have Zippy Compact 5800 8S packs and Hobby Star 5200 8S packs but doing 6+2 is easier.
          • Originally posted by Hurridriver View Post
            I've been running 2 x 4s Admiral Pro 5000 60c, prefer this. But I do on occasion run a 6s + 2s Admiral 5000.
            Lon
            • Sorry for this, but I'm thinking there are a lot of other people like me - have / fly both FW and Eflites...
              Anyway, this pertains to the Eflite Viper 90. I crashed mine and i'm in the process of putting her back together, but i wasn't smart enough to take pics of the nose gear linkage / set-up when i took her apart, so if any of you have one of these birds and would help a brother out, please send me a pic of the nose gear down inside the gear bay so i can see what i should have photographed... and how the linkage all goes back together...
              many thanks in advance if there's anyone that can assist...
              • Originally posted by jasmith41 View Post
                Anyway, this pertains to the Eflite Viper 90...
                Did you ask here?
                • Comment
                  • no, but i figured it out. i was so fkg proud of myself for getting that bird back together and then i took it the field today and 30 seconds after take-off flew it straight into the ground and completely demolished it...
                    not a good day. embarrassed and ashamed.
                      Bummer, man! Been there, done that. Very sorry. 30 seconds to splash down would have been quite a long flight for 2 of mine.
                        Thanks Viper... appreciate the sentiment...
                        • Hey guys, what are you using for a gyro/receiver in the Avanti? I'm interested in what the consensus is, thinking of doing an upgrade in mine, she flies okay, but a gyro would really help.
                            HobbyEagle A3 Super 3 gyro, Spektrum AR8020T RX, Assan G61 steering gyro on nosewheel.
                              Even the most basic of HobbyEagle (A3-L V2, 3-axis, which Motion sells) will work well in a plane like this. However, for the extra couple of bucks, you should look at the newer A3 Evo, 6-axis gyro. Neither needs a programmer. Both can be programmed via the button on the unit.
                              https://www.motionrc.com/products/ea...nt=19071067270
                              https://www.rc-castle.com/index.php?...id=9427&page=1
                              The A3-L V2 will give you your basic gyro stabilization on all 3 control surfaces, while the EVO can also give you an "auto level" capability. I use the A3-L (V1 and V2) in a lot of planes.
                              When you say "a gyro would really help". What specifically are you trying the "help"? My old Avanti behaved wonderfully without a gyro but a friend's Avanti S currently is exhibiting some ground steering issues due to some repeatedly run-ins with the grass lip at the sides and ends of the runway. After a while, the nose strut and steering got so loose, the thing would drive in circles on the ground, even when totally on the runway. In that case, a new nose gear or Assan steering gyro would come in handy. A flight gyro would not help in that regard.
                              • Mine flies pretty good considering what she's been through but she's one of the few that I don't have a gyro in and, let's face it, the gyro smoothens the flight out, especially out here where wind thermals and constantly shifting speeds and directions are common. I have mostly A3L's and love them, but I'm thinking more of the wiring arrangement as you'd have to put the gyro back at the CG and the control box is up front. Hmm, I'll have to give this some thought, thanks for the tips
                                  This is no longer the case for gyros anymore. A gyro doesn't have to be placed at the CG for it to work properly. Take a look at some of the planes that come with gyros already mounted. For example, the SebArt Mig29 comes with its Freewing gyro mounted near the nose cone. Also take a look at the Freewing 90mm F-104. It's Freewing gyro is also mounted right behind the nose cone. I have many planes where the gyro is nowhere near the CG as well as not even being on the centerlne of the plane. The easiest and simplest installation of a gyro is right next to the receiver, where the provided gyro leads are within reach. I've even mounted a gyro on its edge, stuck on the side wall just so it's close to the receiver. My gyro and receiver for my AL-37 is over a foot ahead of the CG.
                                  • My gyro is also all way in the front, below the wooden deck, so around 30cm in front of CG and works ok, never turned it OFF!
                                    87 flights so far with 700°C setup inside...
                                    • 89 flights so far from January.
                                      foam just does not want to quit :)
                                        Great info, thanks Viper. I'd always assumed that they needed to be as close to the CG as possible, this gives me a path forward!
                                          In general, a 3 axis gyro like the A3L has just 3 rotation sensors and is only sensitive to rotations, not linear movements, so it doesn't care where it is located.
                                          A "six axis" gyro has 3 rotation sensors and 3 linear accelerometers, which in principle will react to the direction of the gravitational force along with any accelerations (movements) along the x, y and z axes. So if one of these is placed way off from the CG (such as on a wingtip to give a silly example) it will see the tip move up and down as the plane rolls, and 'think' the plane is climbing or diving and respond in an inappropriate manner. In practice it seems that actual hobby six-axis gyros aren't super sensitive to this effect as long as the gyro is placed in a reasonable location (like NOT on a wingtip or the extreme tail).
