  • sam51401
    • 368
    • Sellersburg IN
    Hey mshagg, you have given an incentive to take my backup A10 out of mothballs and set it up with the 90mm fans you have mentioned. It will be right beside my stock 80mm version and using RT6250's, the flight times are expected to be even more generous. Nice combination you have given, now if i can find two of those AF fans/motor units or the old standard FW fans before they went to the HP versions.
    Update.....looks like I’m in business as I have a set of fans coming and DD is bringing me a set of the modded 90mm nozzles to the Jet Jam this week.
    • themudduck
      -TMD- Foaming at the Mouth!
      • 1041
      • Burton OH (near Cleveland)
      Originally posted by iflyrjs
      Thank you everyone I did find it on Amazon. hoping to see the 3D-printed plastic pod that mounts on a FW weapons pylon on Thingiverse.
      Here you go.... Sleekpod for Insta360 GO camera by Foaminatthemouth - Thingiverse
      • Balsa Bob
        • Sep 2020
        • 59
        • New Hampshire
        Hi All, Just finishing mine up, hope to maiden it soon. I will be using 5000 mah packs. Wondering if the plane balances okay with each pack on the trays ? I thought I had read (somewhere) that some people were relocating the Circuit Module to get it to balance ???
        Thanks. Bob
          • 8791
          Thanks. Bob
          I had to shove the board on mine as far back against the rear bulkhead so that the batteries would both fit back there.
          • Balsa Bob
            • Sep 2020
            • 59
            • New Hampshire
            Thanks xviper, Did you put both batteries back there .... and not use the forward tray above the nose gear for one of the batteries ?
              Balsa Bob I moved the board rearward. I'm using the Admiral 5000mah packs, one on each shelf. Some, that are using heavier packs, had to stack them on the rear shelf in order to get the desired CG.
                • 2696
                Thanks. Bob
                Hey Bob, place the batteries so you can balance somewhere around 90mm. The manual calls for the CG at 78mm, but IMO (and I think most others) that's way too nose heavy, making landings somewhat difficult and potentially having the nose wheel touch first and cause the "Dreaded Bucking Bronco". I found that it flies exceptional, for me anyway, around 93mm back (and that's still no where near being tail heavy, in fact, just barely nose heavy). I'm using 2 RT 6250 mah batteries (get over 5 minutes of flight time) weighing 794 gr, so just like xviper, I removed the circuit board from the back of the rear tray and stuck it on the side fuselage on the port side. The front battery is about 1/3rd hanging over the end of the front battery tray.
                Click image for larger version  Name:	20200926_152819.jpg Views:	0 Size:	76.7 KB ID:	315393Click image for larger version  Name:	20200821_162454.jpg Views:	0 Size:	105.3 KB ID:	315394
                  • 8791
                  Yes, both batteries are back there, actually touching each other.
                  • salali
                    • Sep 2020
                    • 31
                    • Seattle, WA
                    Is anyone using a Spektrum AR630 receiver? If so, can you pls share you experience and where you mounted the receiver?
                    • Balsa Bob
                      • Sep 2020
                      • 59
                      • New Hampshire
                      Do the armament pylons and/or the armaments need to be glued in place .... or do they stay in place okay ?
                      Bob
                      • rlcamden
                        • 112
                        • Lansing, KS
                        I have my receiver mounted inverted under the canopy release button. Tried the 3D receiver/gyro shelf, but liked this location better. I upgraded from the AR6030T to an AR637T. Those should be the same size as yours.
                        • rlcamden
                          • 112
                          • Lansing, KS
                          Bob
                          I didn't glue mine on, but after 4 years of taking the ordinance off and on for transport, the plastic has wore down to the point of when I land on a grass field, it is a guess of which weapons are going to slide off when landing due to the sudden deceleration.
                          • Balsa Bob
                            • Sep 2020
                            • 59
                            • New Hampshire
                            Thanks for the response. I'd be very very happy to have mine loosen up after 4 years !
                            Bob
                            • Miroslav Cerny
                              • 42
                              Hello. I flew my first flight and this plane is really nice and stable. Very nice model.
                              • Balsa Bob
                                • Sep 2020
                                • 59
                                • New Hampshire
                                I purchased the 'upgraded' landing gear main struts. When I lowered the stock gear and got a closer look a them .... they seem very robust and may even perhaps be stronger than the ones I purchased. The stock ones even have a trailing-link type of feature that I like. I guess I'm not exactly sure where the 'upgrade' is on the ones I purchased ......
                                Bob
                                • AndrewF
                                  • Nov 2020
                                  • 45
                                  Hey guys, I’m about to pull the trigger a new EDF. I am currently deciding between this, and the freewing SU-35. Both seem so cool! I like the maneuverability of the SU-35 but the A-10 looks so good in the air. How many of you guys have gone with a 90mm setup on this plane? Is it worth it over the stock 80mm? Do you have to run 8s if you go to the 90mm?
                                  • DCORSAIR
                                    • 1918
                                    • Selma, Ca.
                                    I had two so far, both 80mm, they fly great as is out of the box, I personally thing its a waist of money, I don't see the reason really for the extra power, I mean it will loop and roll and do just about anything you want all stock, the extra beans may be nice, but how fast do you need to go,,,,
                                    • AndrewF
                                      • Nov 2020
                                      • 45
                                      that’s a good point. It’s not meant to be a racer. Plus, the 90mm fan setups are pretty pricey too.
                                        Bob
                                        So the upgraded gear are not really an "upgrade" per se. The stock mains are trailing link type, but the nose is scissor type. If you buy the "upgraded" mains, then all your gear will be the scissor link type. If you buy just the "upgraded" nose gear, then all gear will be the trailing link type.
                                        What happened was that originally the plane was to come with all trailing link type gear. But after posting pictures of the forthcoming plane, a lot of the scale nazis complained that the nose gear did not look right, so they went with a scissor link strut instead, but left the mains as trailing link. What many people found out is that the mains would give on landing, but the nose would bounce back up as it was stiffer and would get you into the dreaded bunny hop. So they then offered these "upgrades" so that you could make the gear all of one type.
                                          If you get this, stick with stock. There is absolutely no need to upgrade to 90mm on this one. Like DC said, it flies fantastic right out of the box, and upgrading to 90mm is just a waste of money.
