I had a mishap with my front gear doors. Damaged one. Can I fly the plane without them until the replacements come in?
Lon
Freewing A-10 80mm, F-86 80mm, F-15 90mm, F-16 90mm. Avanti. FMS DHC-2 Beaver, Fliteline P-38L ,HSD HME-262, HSD F86.Comment
Kinda like an A-10, it will fly with all kinds of damage and missing parts. Flies fine without the nose, too. I imagine would not "need" the canopy. For me, flies better without the fences (turns better), but can help for belly landings. Be sure to tape the hinge lines, they eventually tear. Check all the glue and screws so it doesn't fall apart in the air! Tug on all of the parts. They had some batches with a white glue that would barely stick and the aileron servos are glued to the paint! Watch the servo horn screws, they can unscrew. They are metal to metal with no thread lock. Do NOT set the flaps to full mechanical throw, the servos can stall.Comment
I Really don't know where else to post this but this seems like the right thread.
It started as an idea which led to a dare and then it was said it couldn't be done.
Well guess what!!!!
My idea and Avantis 1 Of which was salvaged from the trash and a flying buddy that accepted the challenge.
6 Gear 2 nose and 4 mains
4 flaps
2 80mm EDF's
49" long
74" span
1 PhotoComment
Now that's what I call a TIGHT flying formation! 1 RX? I see you have it tied together at the tail at the 2 inside horizontal stabilizers. What about in the center under the wing to each fuselage, or is it just joined via the inside wings tips? Seems to fly very stable.I Really don't know where else to post this but this seems like the right thread.
Well guess what!!!!
4 flaps
2 80mm EDF's
49" long
74" span
https://youtu.be/PX5979TbP1Q
How does in roll?
2 Receivers. Center section is carbon fiber reinforced. I can unbolt the tail connector (plexiglass) so invisible in the air, take out center section put the separate wings on and have 2 flying Avanti's. but that's no fun :)
How does in roll?
That was maiden flight. Might try a roll tomorrow.
Voodoo blade post it on the live show here https://www.hobbysquawk.com/forum/th...ive-show/page2I Really don't know where else to post this but this seems like the right thread.
Well guess what!!!!
4 flaps
2 80mm EDF's
49" long
74" span
https://youtu.be/PX5979TbP1QComment
Thanks I did !!!!
Voodoo blade post it on the live show here https://www.hobbysquawk.com/forum/th...ive-show/page2Comment
When I asked if there was 1 RX, my first thought was "Now that's a Stupid Question", how can there be 2 RX's? Now that you say you are using 2 RX's, time for a real stupid question. How did you bind 2 separate RX's to one transmitter? Didn't know that was even possible as every time I bind a Spektrum RX to my Spektrum TX, it "eliminates" any other RX that was bound to it before. I'm not the "sharpest tack" in the bunch, especially when it comes to TX/RX and other electronics but always willing to learn a new trick. Thanks.
That was maiden flight. Might try a roll tomorrow.Hugh "Wildman" Wiedman
Until yesterday I didn't know it was possible either LOL I put both in bind mode and and hit the bind button on transmitter and they did!!!
I can take the center section out plug the wings into each separate fuselage and can fly either one as a single Avanti.
So basically each receiver is doing the exact same thing but its like the inboard aileron servos are not plugged in. absolutely no wires cross between the 2 planes and no y connectors tying in servos from one side to the other.
Ohhh also It does a good loop but I will not be doing anymore rolls LOL it didn't like it at allComment
That makes perfect sense -- however you are loosing considerable authority. Hmmmm.....
Since the real aerodynamic center of the aircraft is between the two fuse -- what about having both ailerons on the right half move in tandem and both on the left move in tandem??Comment
It would be a lot simpler to just move the control rod/horn hole positions to increase the aileron throws to give more authority if that is what is required. or just dont roll it, after all its just for fun !
Otherwise presumably you will have to put ailerons on separate channels and then reverse one of them in each plane. and if you have a 6ch rx that aint going to happen!!!. If you do have 6 channel rx then taking Evan`s point a couple of pins in the inner ailerons wont go amiss as long as you remember to take em out after separating the 2 planes !!!Comment
That would work but as the two inner ailerons are so close to the center of roll they act as air brakes as much as ailerons.
I'm not aware of any problem binding two receivers to the same transmitter model. Binding two transmitter models to the same receiver is not possible unless you do a "model match overrride", for obvious safety reasons.
When I asked if there was 1 RX, my first thought was "Now that's a Stupid Question", how can there be 2 RX's? Now that you say you are using 2 RX's, time for a real stupid question. How did you bind 2 separate RX's to one transmitter? Didn't know that was even possible as every time I bind a Spektrum RX to my Spektrum TX, it "eliminates" any other RX that was bound to it before. I'm not the "sharpest tack" in the bunch, especially when it comes to TX/RX and other electronics but always willing to learn a new trick. Thanks.Comment
I’m thinking of getting the Avanti S to progress from my Eflite Habu. I’m very low houred on RC flying and my Habu has all the SAFE features which has allowed me to progress onto EDF jets quickly. Do you think the Avanti will be a step too far at the moment?Comment
What exactly do you mean by "all the SAFE features"? If you have SAFE enabled 100% of the time you will not be flying the Avanti (or your Habu) to anything like its full potential.
