  • Lextek
    • Sep 2019
    • 19
    • Farmington, NY
    I had a mishap with my front gear doors. Damaged one. Can I fly the plane without them until the replacements come in?
    • Lon
      • Jul 2014
      • 1202
      • Miles, Iowa
      I have. Same situation as you. I couldn't tell the difference when flying.
      Lon
      • Mach9
        • Jun 2017
        • 123
        Kinda like an A-10, it will fly with all kinds of damage and missing parts. Flies fine without the nose, too. I imagine would not "need" the canopy. For me, flies better without the fences (turns better), but can help for belly landings. Be sure to tape the hinge lines, they eventually tear. Check all the glue and screws so it doesn't fall apart in the air! Tug on all of the parts. They had some batches with a white glue that would barely stick and the aileron servos are glued to the paint! Watch the servo horn screws, they can unscrew. They are metal to metal with no thread lock. Do NOT set the flaps to full mechanical throw, the servos can stall.
        • VoodooBlade
          • 7
          I Really don't know where else to post this but this seems like the right thread.
          It started as an idea which led to a dare and then it was said it couldn't be done.
          Well guess what!!!!
          My idea and Avantis 1 Of which was salvaged from the trash and a flying buddy that accepted the challenge.
          6 Gear 2 nose and 4 mains
          4 flaps
          2 80mm EDF's
          49" long
          74" span
            • 2715
            Well guess what!!!!
            4 flaps
            2 80mm EDF's
            49" long
            74" span
            https://youtu.be/PX5979TbP1Q
            Now that's what I call a TIGHT flying formation! 1 RX? I see you have it tied together at the tail at the 2 inside horizontal stabilizers. What about in the center under the wing to each fuselage, or is it just joined via the inside wings tips? Seems to fly very stable. How does in roll?
            • VoodooBlade
              • 7
              2 Receivers. Center section is carbon fiber reinforced. I can unbolt the tail connector (plexiglass) so invisible in the air, take out center section put the separate wings on and have 2 flying Avanti's. but that's no fun :)
              That was maiden flight. Might try a roll tomorrow.
                • 5402
                Cool! Amazing how well it'll turn on the ground too. Like a race car.
                • paulrkytek
                  • Jun 2019
                  • 531
                  • North of England
                  Well guess what!!!!
                  4 flaps
                  2 80mm EDF's
                  49" long
                  74" span
                  Voodoo blade post it on the live show here https://www.hobbysquawk.com/forum/th...ive-show/page2
                  • VoodooBlade
                    • 7
                    Thanks I did !!!!
                      • 2715
                      When I asked if there was 1 RX, my first thought was "Now that's a Stupid Question", how can there be 2 RX's? Now that you say you are using 2 RX's, time for a real stupid question. How did you bind 2 separate RX's to one transmitter? Didn't know that was even possible as every time I bind a Spektrum RX to my Spektrum TX, it "eliminates" any other RX that was bound to it before. I'm not the "sharpest tack" in the bunch, especially when it comes to TX/RX and other electronics but always willing to learn a new trick. Thanks.
                      • VoodooBlade
                        • 7
                        Until yesterday I didn't know it was possible either LOL I put both in bind mode and and hit the bind button on transmitter and they did!!!
                        I can take the center section out plug the wings into each separate fuselage and can fly either one as a single Avanti.
                        So basically each receiver is doing the exact same thing but its like the inboard aileron servos are not plugged in. absolutely no wires cross between the 2 planes and no y connectors tying in servos from one side to the other.
                        Ohhh also It does a good loop but I will not be doing anymore rolls LOL it didn't like it at all
                          • 5402
                          Disable the inner ailerons. Don't just unplug them as the air can push them and that's bad. Best to plug them into a separate channel on the receiver and don't program in any throw.
                          • Scott Page
                            • Jan 2021
                            • 14
                            That makes perfect sense -- however you are loosing considerable authority. Hmmmm.....
                            Since the real aerodynamic center of the aircraft is between the two fuse -- what about having both ailerons on the right half move in tandem and both on the left move in tandem??
                            • paulrkytek
                              • Jun 2019
                              • 531
                              • North of England
                              It would be a lot simpler to just move the control rod/horn hole positions to increase the aileron throws to give more authority if that is what is required. or just dont roll it, after all its just for fun !
                              Otherwise presumably you will have to put ailerons on separate channels and then reverse one of them in each plane. and if you have a 6ch rx that aint going to happen!!!. If you do have 6 channel rx then taking Evan`s point a couple of pins in the inner ailerons wont go amiss as long as you remember to take em out after separating the 2 planes !!!
                                • 5402
                                That would work but as the two inner ailerons are so close to the center of roll they act as air brakes as much as ailerons.
                                • kallend
                                  • 1877
                                  I'm not aware of any problem binding two receivers to the same transmitter model. Binding two transmitter models to the same receiver is not possible unless you do a "model match overrride", for obvious safety reasons.
                                  • Simon Bee
                                    • Oct 2021
                                    • 135
                                    • Leeds UK
                                    I’m thinking of getting the Avanti S to progress from my Eflite Habu. I’m very low houred on RC flying and my Habu has all the SAFE features which has allowed me to progress onto EDF jets quickly. Do you think the Avanti will be a step too far at the moment?
                                      • 5402
                                      The Avanti is easier to fly in general. Put a safe receiver in it…
                                      • Simon Bee
                                        • Oct 2021
                                        • 135
                                        • Leeds UK
                                        Ok thanks, can you give me a link for a suitable Safe receiver ?
                                        cheers
                                        PS, the place I fly is grass only. Is it OK on grass ?
                                        • kallend
                                          • 1877
                                          What exactly do you mean by "all the SAFE features"? If you have SAFE enabled 100% of the time you will not be flying the Avanti (or your Habu) to anything like its full potential.
