my Avanti-S just finished her maiden and the first few test flights a few days ago...and she does fly great but to be honest i was a bit surprised that the aileron numbers from the manual were way to high in my opinion...and i mean way to high...and i went even lower that the low from the manual as my high, and she still felt a litke a drill to me....so lucky that this thing can fly as slow as a falling leaf...so no harm in the end. A few test flights later and she is dialed in now...at least good enough to start with the rework into the M-Version...added an engine and landing lights so far, while my 3d-printer is doing his thing....this gives me some more time to finish the cockpit and the decals...
You should not be surprised or shocked that your rates and expo are different than anyone else's. Rates/expo is different for everyone based on their own flying style, experience and skill level and the way each plane is set up (battery placement, etc.) and whether or not a gyro is used and how that gyro is set up (gains, etc). Some people don't even use less rates or any expo at all they feel perfectly comfortable with the plane that way, while others have been known to go as low as 25% rates and 50%+ expo. This may mean very little to anyone else except the pilot flying that plane. They may also have the control rods in different holes on the servo arm and on the control surface arm.Comment
Correct. 32% of what as the "full" travel may be different for different people. Also different radios may produce different surface throws even though both are at 32%.
Setting your rates, either servo travel or in dual rates to a low value like 32% is a really bad way to set an amount of surface throw. You are reducing the resolution the servo see's and will have poor mechanical advantage. The much better way is to keep 100% or more in the radio and change your servo to horn linkage to reduce the surface deflection. Usually we can't move the push rod to a more outer hole on the surface horn so we have to move the pushrod in on the servo arm a hole or two.
After I read this advice, I did it on a few of my planes where I was using very low rates. The end result was a much smoother control surface operation and a higher confidence level when flying those planes. I pointed out this method to a couple of my flying buddies who also adopted it and they too, are much happier with their planes performance.Comment
Archimedes could have told us that 2,200 years ago.Correct. 32% of what as the "full" travel may be different for different people. Also different radios may produce different surface throws even though both are at 32%.
Setting your rates, either servo travel or in dual rates to a low value like 32% is a really bad way to set an amount of surface throw. You are reducing the resolution the servo see's and will have poor mechanical advantage. The much better way is to keep 100% or more in the radio and change your servo to horn linkage to reduce the surface deflection. Usually we can't move the push rod to a more outer hole on the surface horn so we have to move the pushrod in on the servo arm a hole or two.Comment
The turbine guys are putting Freewing T-33 retract mechanism and modify the Avanti struts. That is what I have on mine.Comment
Absolutely fantastic recommendation! It took an hour or so each side but now my gear operate flawlessly even with the weight of the heavy wheels and brakes. The big challenge was to hold the strut in a vise on my drill press. I drilled one side perfectly, the other side was a tad off, but I am a perfectionist.... Robbie you are the best!Comment
ESC Cooling Vents?
I just ordered one and was wondering.
I fly in the southwest and have found that the ESC on the Eflite Viper 90mm, F-16 80mm, and FMS Futura V3 80mm does not cool properly and get really hot in our hot weather. The only venting on all of them is a slotted piece of wood on the inside of tube. For each of the above EDF’s I had to install vents cut into the fuselage.
How is the cooling on the EDF? Are you guys installing vents?
Pictures much appreciated. 🙏
